Cleaning up my IC piping before the install. :)
Old Dec 6, 2010 | 10:08 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Default Cleaning up my IC piping before the install. :)
Before and after pics; I didn't finish all the piping yet but...you get the idea. I can't wait unitil it is all polished up and ready for the install in the Spring!
Attached Thumbnails Cleaning up my IC piping before the install. :)-pc021652.jpg   Cleaning up my IC piping before the install. :)-pc021653.jpg
Old Dec 6, 2010 | 07:09 PM
sakataj's Avatar
sakataj
nice work so far rock, now lets see the SC also
Old Dec 6, 2010 | 07:34 PM
JeffTsai's Avatar
JeffTsai
Was that rust on the pipes? I thought SRT used aluminum piping?
Old Dec 6, 2010 | 08:34 PM
Alexus_300's Avatar
Alexus_300
Yup, that looks like rust.. He might want to get that pipe remade and I'm not liking the sharp 90 degree bends on those intercooler pipe at all.
Old Dec 7, 2010 | 09:07 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Yup...it was surface rust...came right off though. I think the piping is in fact aluminum though...it feels exactly like other aluminum piping that I bought a while back when I was trying to make a cold air setup on my intake.
The piping was powder coated silver with surface rust. It looks SICK right now. Mainly the rust was on the two pipes down low connecting to (and from) the intercooler.
Old Dec 7, 2010 | 09:12 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Why would I want to get the pipe re-made? The surface rust comes right off. If the 90 deg bend bothers you...I am not about to change all the piping (because if you thange the angle/pitch of one you have to start adjusting/changing all of them) and spend tons of $$$ just to be able to squeeze out 20whp more. lol
When Mr. Johnson had this kit he was making around 418whp and around 365wtq and that was WITHOUT headers. I have headers and I am actually going to scale down on the power levels (by using the larger pulley) to say around 380whp or so; I'll be happy with that. So, all in all I really don't care about the 90 deg bend that much if it impedes power levels because I am NOT trying to wringe ever last bit of power out of this setup. The tranny will remain stock with just perhaps the addition of a VB upgrade.
Old Dec 7, 2010 | 11:01 AM
Alexus_300's Avatar
Alexus_300
What I'm trying to suggest was that since the piping had rust on it already, you might need to change the piping. But since you said that it was surface rust, you might be able to get by with it. I've seen kits out there before using a lower grade of aluminum which contains some metallic compound in it which results in rust. For peace of mind, I would say take the pipe that was rusted and have it pressure tested. A radiator shop should be able to test it for you for $20 max.
Old Dec 7, 2010 | 01:47 PM
speedaddic's Avatar
speedaddic
nothing wrong with the 90 degree bend Rock...keep the pipes. If the rust bothers you, get it coated.
Old Dec 7, 2010 | 01:53 PM
Mr Jokster's Avatar
Mr Jokster
Just put a magnet to it and see if its sticks
Old Dec 8, 2010 | 06:11 AM
Rock-a-Lex's Avatar
Rock-a-Lex
You guys are ABSOLUTELY CORRECT! I contacted SRT and they said that all their kits back then (10 years ago) were done with mild steel; they switched to aluminum about 4 years ago. So, yes...it is mild steel. I tell you what though; it polishes up SICK!!!
Also, I contacted a high-end powder coating company that deals exclusively with car parts (local to me) and they said that for about $150 they can powder coat ALL piping with a clear, special high heat powder coat that WILL adhere to highly polished mild steel piping as they have done it plenty of times.
So, it's cool to know that I won't have to scuff the piping up at all. I like the polished look a lot. Powder coat black is also nice but I'd like a little bling in the engine bay.
Old Dec 11, 2010 | 07:23 PM
passnu2's Avatar
passnu2
the pipes are just fine. no need to spend the money to replace. I would just powder coat them to help them against weather.
man I cant wait to see how this comes together and what the headers add to the mix.
Old Dec 12, 2010 | 11:58 AM
TLcoats's Avatar
TLcoats
Wow Rock! I had no idea you were going SC. Thanks for letting me know! Sorry i'm just a little jealous of you. Make sure to post lots of pics and vids of the whole process! Can't wait to see the finished product.
Old Dec 13, 2010 | 10:58 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Agreed!!!!!!!
Old Dec 13, 2010 | 10:59 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Yeah, I know...I kinda surprised myself on this one. lol I WILL promise that I will make lots of videos when finished...you can count on that!
Old Dec 13, 2010 | 11:28 AM
Rising_Sun's Avatar
Rising_Sun
Dayum Rock! The kit looks sick! Let me know if you need a hand putting it together!
