Remove resonators or install x-pipe?
Old Aug 3, 2010 | 09:29 PM
FinLIFE's Avatar
FinLIFE
Default Remove resonators or install x-pipe?
I have an 01 gs430 and currently I have an apex ws2 installed, but I want a little more sound out of it. Whats a better idea? to remove the two resonators or to install an x-pipe?? thanks
Old Aug 4, 2010 | 08:19 AM
JBrady's Avatar
JBrady
Remove the two resonators OR do a muffler delete. Start with the delete. If you like it you can have pipes installed to extend to the bumper.
The 430s have a center catalyst that I do NOT recommend replacing with an X, H or Y pipe.
Old Aug 4, 2010 | 09:55 AM
FinLIFE's Avatar
FinLIFE
Thank you sir, I think ill start with getting rid of the resonators. I don't want it much louder plus I like the look of the mufflers.
Old Aug 5, 2010 | 07:45 PM
unclej's Avatar
unclej
Do Both the x-pipe 1st
Old Aug 8, 2010 | 08:49 AM
kit cat's Avatar
kit cat
I have my resonators deleted with stock mufflers. PM me if you want to hear it..i'm in Chicago too.
Old Aug 8, 2010 | 10:02 AM
PANAnVEGAS's Avatar
PANAnVEGAS
Go with both of them!
Old Aug 8, 2010 | 10:12 AM
PANAnVEGAS's Avatar
PANAnVEGAS
My reason for saying both is because my G8 GT Pontiac (different of course) has th 6.0 V8. I actually went with the H-pipes instead of the X-pipe deleted both resonators and added the magnaflows and it wasnt very loud until i got on it. Even then it was enough to make heads turn without sounding like a exhaust job on a Harley at WOT!
Old Aug 8, 2010 | 10:31 AM
JBrady's Avatar
JBrady
Again, the 430 has a center catalyst. I do not recommend removing it for several reasons. Just do the twin resonators if you must keep your final mufflers.
Old Aug 8, 2010 | 05:28 PM
Frankdorn's Avatar
Frankdorn
Same with the 400's?
Also, where does a guy find the correct size X-pipe? 2-1/8 ID in and out, right?
Old Aug 8, 2010 | 06:31 PM
GSJake's Avatar
GSJake
CL Folding 200,000
Whats up Frankdorn! (Chis or Matt right> ) Anyway, the 3rd center muffler is just a resonator on your car. 400 had two cats that feed into a resonator where the 430 has a cat there.
Old Aug 9, 2010 | 08:56 AM
JBrady's Avatar
JBrady
GS400 has a single center resonator not a cat.
The single center pipe is 60mm = 2.36" OD
The twin pipes from the engine to the Y are 50mm = 1.97" OD
The way the stock Y pipes works is better than MOST Y or X or H pipes you can find.
Why do you want an X pipe? Sound?
Old Aug 9, 2010 | 11:08 AM
Frankdorn's Avatar
Frankdorn
I was thinking X-pipe for a little more grunt and flow, thinking maybe 5hp, I dunno. Gotta pull everything down for the TC and header install here anyway. I won't bother having it done if the differences in flow are that marginal, though.
I feel kinda stupid, but to confirm, the 400's exhaust layout is this, correct?:
(Front of car)
Header Header
Cat Cat
Y-pipe
Resonator
Y-pipe
Resonator Resonator
Muffler Muffler
Old Aug 10, 2010 | 09:44 PM
JBrady's Avatar
JBrady
(Front of car)
Header Header
Cat Cat
Y-pipe
Resonator
Y-pipe
Resonator Resonator
Muffler Muffler
correct
also, it is more likely that you will not gain anything or even loose by changing the front Y pipe
Old Sep 16, 2010 | 02:58 PM
kit cat's Avatar
kit cat
Dear CL members,
I do NOT have any clips and cannot email/PM you a clip I don't have.
kthxbai
ZhiuPei
Performance
27
Nov 25, 2022 02:25 PM
likaboss22
Mar 14, 2016 07:37 AM
gsean400
Performance
Jan 29, 2014 10:45 AM
gsean400
Oct 31, 2013 07:58 AM
Patrician
Dec 25, 2012 07:21 PM
