2002 Won't Start After Installing Weapon*R Intake
Old May 4, 2002 | 08:28 AM
StylinGS300's Avatar
StylinGS300
Post 2002 GS300 Won't Start After Installing Weapon*R Intake
Help everyone! After I installed Weapon*R intake, my car won't start. I checked all the connection and everything is connected where they're suppose to be. I even disconnected the battery to reset the computer system and the car still won't start. Of course, I reconnected the battery. The car start up fine after I reinstall the factory intake. Any advice would be appreciated.
Old May 4, 2002 | 08:35 AM
LexusRules's Avatar
LexusRules
did you install the MAF backwards? turn it around and try again.
Old May 4, 2002 | 02:01 PM
RacingAristo
Guest
Posts: n/a
Yeah, that's the mistake that most people would have. Did it fix your problem?
Old May 5, 2002 | 07:55 AM
StylinGS300
Thanks guys! The car starts now. This morning when I start up the GS stalled. It seem like it didn't get enough air. The engine was choking, shaking and then stall. Do I have to adjust anything? If so, what?
The GS lag between 700-1500rpm. It seem like it doesn't want to move. Any advice is appreciated.
Old May 5, 2002 | 08:16 AM
LexusRules's Avatar
LexusRules
make sure the vaccum lines are hooked up right, and then re-reset the ECU and if it still happens re-post.
Old May 5, 2002 | 08:21 AM
StylinGS300
I rechecked the vaccum hoses and it's connected correctly. I did reset the ECU. It's still lag.
Old May 5, 2002 | 08:59 AM
RacingAristo
Guest
Posts: n/a
How about giving WR Tech department a call?
Old May 6, 2002 | 01:51 PM
CamRen's Avatar
CamRen
one of three things:
<> everything not sealed tight... ( rubber gasket inbetween intake and sensor)
<> ECU reset for 20-30 mins then drive for 5-10 mins... it should be ok after that.
<> something wrong with the speed sensor ( dunno what though ... when i had this issue ... thats what the problem was .... thats what the lexus shop said @ least)
Old May 6, 2002 | 02:37 PM
CSHFLW's Avatar
CSHFLW
It could be the wrong pipe...I got a bad one and had to send it in....is the air diffusser on the side closest the throttle body or the filter?
Old May 7, 2002 | 07:39 PM
StylinGS300
Thank you everyone for your advice. The sensor holes was welding backward and the MAF sensor was linking air. I'm sending it to Weapon*R and they'll send me another pipe. Once again thank you for all of your advice.
Old May 7, 2002 | 08:32 PM
StylinGS300
To reset the ECU all I have to do is disconnect the battery for 20 to 30 mins. Is that correct? The reason I ask is because I don't know much about cars. I just drive them.
Old May 8, 2002 | 04:41 AM
LexusRules's Avatar
LexusRules
disconnect the negitive
sorry about your bad experiance with WR intake.
1sWt2GS
Nov 6, 2016 09:24 PM
cheatdeath
Performance
30
Mar 4, 2011 02:47 PM
fatkidGS3
Apr 23, 2010 03:40 PM
818GS
Oct 11, 2009 10:45 PM
