aem fic -8 install!
Old Jan 28, 2009 | 08:16 AM
velella's Avatar
velella
Default aem fic -8 install!
ok guys, i just bought a fic -8 and will be installing it next week. ive been reading alot about this stuff from you guys and have a few questions.
1.) i see you guys have been confused about the o2 sensors, what o2's do i do what with, i see people saying different things.
2.) where are you guys mounting your fic?
3.) what else do i need to buy to et rid of the maf? i know its easy to do with the fic but i dont know what else i need.
im installing this a month before my turbo install, so is there anything else i should do before the install? im going to just keep the stock tune so i think im going to keep all the settings on the fic at 0?
also can the fic -8 change the injectors, like high and low imp? i wanna know if my extra set of 550cc injectors from a gte will work now in the 99gs300
Old Jan 28, 2009 | 11:16 AM
sakataj's Avatar
sakataj
check this post
https://www.clublexus.com/forums/per...c-install.html
Old Jan 28, 2009 | 12:25 PM
jcat_350's Avatar
jcat_350
i thought the fic 8 channel was for 8cyl engines....
Old Jan 28, 2009 | 10:14 PM
velella's Avatar
velella
is can control up to 8 injectors, its the higher model that can do boost control and crap.i got a great deal on one so i didn't pass it up!
Old Jan 28, 2009 | 10:20 PM
ElitistK's Avatar
ElitistK
1. the o2 map is used for fine tuning your fuel map. It's to tamper with the o2 voltage output to compensate for the extra fuel you might be adding in the fuel map.
2. behind the driver side headlight. I should have made an extended harness for it though and mount it elsewhere.
3. don't get rid of the maf. long story short but you will not be able to drive the car as long as you're still using the stock ecu.
4. i have a sticky thread on clubna-t in the fic section about this already.
5. search my posts on clubna-t and you will find most answers.
maf != karmen vortex. the vvti gte actually uses a maf sensor believe it or not.
Old Jan 29, 2009 | 08:59 AM
velella's Avatar
velella
wait the vvti ge is a karman vortex??? i thought that was only the non vvti's. and alot of people told me you could eliminate the maf and go to a map sensor instead. why cant you do this?
Old Jan 29, 2009 | 09:09 AM
ElitistK's Avatar
ElitistK
!= means not equal. it's a computer programming term sorry for the misunderstanding. I was trying to point out that the MAF actually has the ability to tune for a boosted system, unlike KV which just totally craps out.
As long as you're automatic, your vvti ge ecu will be using the maf to determine shift points; without it your ecu cannot really shift properly. Also, your gas tank gauge would be off because that also uses the maf. The maf itself actually has an air intake temp sensor, but if you're good with wiring you can just wire in a separate AIT.
Since you're running a low psi, i would assume the CFM won't really exceed the maf's reading ability by too much to go through all this trouble just to use a map sensor. Just make sure that your ecu doesn't go into a static tune mode by capping the MAF voltage at 4.7V. If you insist on using a map sensor, you will have to:
1. make a MAF voltage table in the FIC that converts your MAP sensor reading to MAF voltages output to the ecu.
2. AIT sensor
3. wiring necessary
edit: come to think of it, you could just keep the MAF in the system for AIT's sake, and use the fic map sensor to tune. Getting the MAF voltage table output exactly how it should be is a very daunting task though. Someone did it with a supra non-vvti the thread shoudl still be around on the aem forums.
Old Jan 29, 2009 | 09:12 AM
jcat_350's Avatar
jcat_350
kenny, what's the limit as far as boost pressure on the stock GE maf?
Old Jan 29, 2009 | 11:30 AM
ElitistK's Avatar
ElitistK
it's very hard to say because i never tried it out. the key of tuning a piggyback is that you are relying on the fact that the ecu goes into open loop when you go WOT. As long as you are WOT, the MAF reading could be capped at 4.7V and you can add additional fuel in the corresponding PSI level in the fuel table without upsetting the ECU fuel trims. For anything other than WOT, i would just keep the MAF and let the ecu do most of its work.
Old Jan 29, 2009 | 12:21 PM
velella's Avatar
velella
wow, yea awesome info, i never would have thought about the maf and shift points! i think ill be keeping the maf for now just because im at low boost so until i turn it up alot more i will probably just keep it.
anyone know if the fic can control water meth?
Old Jan 29, 2009 | 12:22 PM
ElitistK's Avatar
ElitistK
the switch 12Vdc output is your best friend. It has 1.2A more than enough to trigger most relay setups.
velella
Performance
Jan 27, 2009 06:30 PM
1JZ300
Nov 7, 2007 10:54 PM
lexcoupe
Nov 10, 2001 04:36 PM
