find me a scientific proof that high mileage cars will certainly leak oil going from conventional to synthetic.
if you went from conventional to synthetic and you're getting leaks, that means your seals are bad in the first place; conventional oil just masks the problem because of less cleaning agents in the oil.
lol...that was the point...at that high of miles your seals are most likely bad...and the normal oil was just masking the problem...but that doesnt change the fact that what I originally said was true..
"synthetic is best..but if you have been using normal motor oil you will probably have a small leak (most likely at gaskets aka "seals")"
The point was that you would most likely have to replace some seals/gaskets...
and, a cars engine does wear down..your theory of (it got you that far, no sense in changing...) is not based on anything scientific..(would you say that about tires? no..) a engine does wear down..and get leaks/etc.. and at 114K...that engine has tons of life left..so why would you not want to do something to keep it running at optimal performance?
This is sort of my point too though so we agree, but let me clarify and make a point.
I asked the OP to say if there are any symptoms he was trying to address.
If you have zero symptoms, then use the manf recommended until something shows up.
If you have leaks or engine rattling or something, then you address that symptom regardless of age, it could be at 30k, 100k, 500k. The symptom also might not be solved by a different oil, so don't automatically go to that solution.
To say use a thicker grade of oil for older cars doesn't make sense.
What you really want to say is if your car has a leaky seal burning oil, then use a thicker oil to get around that leak.
i dont want to fight about oil..lol but i think ppl are forgetting that 10w30 is recommended in the owners manual..and thats what i suggested, not anything different or weird...(it comes with 5w30 because it is just the best universal oil for every application)
ok, why dont we just leave this pissing contest with useful information.
5w30 is recommended (i can at least say for sure on my 01 gs3, dont know about older or gs4 models.). 10w30 is fine to use, just not in super cold climates. If your only reason for running a higher viscosity oil is to 'get around' a leak, this wont solve your problem. If you have a leak, if you're burning oil, fix the damn thing right. Using higher viscosity oil is only a bandaid and will likely hurt more than help in the long run.
synthetic, blend, or standard, whatever you want to use just keep it consistent. If you are switching from standard to synthetic, i personally would recommend running a blend for at least 2 oil change cycles before going full synthetic.
end of story, period.
and ford, it's 5w30 in the manual, as is on the oil cap on top of the engine.
Ok, i agree with what you said, except for one thing...im not trying to argue..just think about it...as an engine gets older (more miles) whether you like it or not..things wear down and it gets to a point (not talking about leaks fyi) where 10w30 lubricates it the same as 5w30 because of the fact that everything isn't as nice and tight/sealed as it was new..and the only way to fix that would be a complete rebuild...i seriously would have stopped..but i hate ppl telling me im wrong when im not..i just took out my book and check it AGAIN, and the FACTORY OWNERS MANUAL says 5w30 OR 10w30...so please just look at your book before you tell someone off again...
oh and i have a 98..and the OP has a 99..so for us..this is true..if they changed the manual in 01+ then sorry...
There are plenty of people who switched to synthetic at 200k+ miles without any problems. Given the same year, some low mileage cars that are over a decade old sometimes have seals and gaskets worse than a higher mileage car. The reason why i say your statement is a myth because it's not even half true for most applications. It might sound true on paper, but in real life it's not true for all.
i don't even know why you guys are fighting over 5w30 and 10w30. it's technically the same weight at operating temperature, just one is better for cold start.
edit: if you really want to learn about motor oil, go on a motor oil forum.
im just going off of my personal experience..and the fact that i just got done with a class that spent 2 weeks on oil, its effects,and different kinds... i need new valve cover gaskets..guess what..they didn't start leaking until i switched to synthetic..yea they probable needed to be replaced before..but the leak started when i switched..
