Gas Mileage Down The Drain
Old Oct 21, 2008 | 08:07 PM
  #61
sam430's Avatar
sam430
I try to reach the tire max PSI. I just inflated today to 45-48 PSI. I have lead foot so...more fun for me!
Old Oct 21, 2008 | 08:38 PM
  #62
jcat_350's Avatar
jcat_350
and then when you hit a nice big speed bump or similar your tires will just blow out on you and that lead foot of yours will do nothing for you
there's a reason there are suggested tire pressures. a few psi i can understand, but you do realize that you're between 15-18 psi over stock recommendation.
that's 1.5 times the pressure, meaning 1.5 times less absorption of road geography. think about it.
Old Oct 22, 2008 | 05:21 AM
  #63
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
So what's the final result then? I've been running my tires at about 38 psi ever since I read this thread, does everyone agree this is the best tire pressure? would 40 be better? 36?
Old Oct 22, 2008 | 06:08 AM
  #64
Mike813's Avatar
Mike813
i would say 34-35 the max on cold "oem" rims/tires... once it warms up your tires are reading 40 or higher. just need to make sure every1 checks their pressure while its cold.
1 mile drive = tires are warm anything under is considered "cold" readings still.
Old Oct 22, 2008 | 06:50 AM
  #65
jamodeo's Avatar
jamodeo
I really don't know how this worked out but I get about 8MPG (mostly city driving) and I went on a road trip this weekend to indiana (300 or so miles away) and on the highway with the windows down, cruise control most of the way, I was averaging 26MPG and it was crazy, Then I drove back here and then some on one tank. especially gas being 2.89 for BP Ultimate (No Ethanol ), I felt like I was in heaven haha... I stopped at almost every BP on the way home just to fill up with the 0% ethanol gas, and it was much cheaper... Could the no ethanol make a difference, or was it just that the constant speed that helped the MPG (or maybe both) just happy that the V8 was pulling numbers like that...
-Joe
Last edited by jamodeo; Oct 22, 2008 at 06:51 AM. Reason: i can't spell or proof read haha
Old Oct 22, 2008 | 07:13 AM
  #66
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
Yea I meant I was at that psi reading cold ... And I have the stock 16" rims but not tires, my tires are bridgestone potenza RE050, and they are rated at 52 psi max cold, so i used to run them at 40 but someone told me that was bad, if it's bad then why would the tires have that 52 psi max cold on them?
Old Oct 22, 2008 | 03:18 PM
  #67
MJImport's Avatar
MJImport
Tires go into the engineering of the car's overall suspension system. If you increase the pressure of the tire you increase the "spring rate" meaning other components are absorbing more impact.
As far as blow-outs go, if your tires are less than a year old and have at least 50% tread, I seriously doubt they would fail if you run close to the max pressure. That pressure has to have some safety factor engineered into it to address concern with liability for the tire manufacturer
Old Oct 22, 2008 | 03:19 PM
  #68
MJImport's Avatar
MJImport
A bit of a trade-off, save money on gas now, spend it later on struts.
Old Oct 22, 2008 | 03:21 PM
  #69
jcat_350's Avatar
jcat_350
-Joe
dude, if you're getting 8mpg even with the v8, you either need some serious maintenance or serious driving lessons.....
my ML430 with my heavy *** foot even got 14-16, and thats with a 4.3 and full time all wheel drive
Old May 26, 2010 | 11:04 AM
  #70
xfea's Avatar
xfea
I have a general question about MPG.
I have a stock '01 GS 300.
Stock suspension (except for Bilstein Sport Shocks) stock 16 wheels and OEM size tires 215/60-16.
The best millage I ever got was driving non-stop on I5 from LA to San Jose - 23MPG.
Around town with a bit of freeway driving I get about 17MPG.
Is this as good as it gets?
Old May 26, 2010 | 12:57 PM
  #71
dejavu157's Avatar
dejavu157
hmm i get around 17mpg on my car, and i drive really slow too
Old May 26, 2010 | 01:14 PM
  #72
xfea's Avatar
xfea
Bummer - that sucks.
I was getting better with my '06 Mustang GT..
And the new 6 cylinder Mustang - 305 HP and 31 MPG.
Old May 26, 2010 | 02:21 PM
  #73
sakataj's Avatar
sakataj
search
just start with your normal item guys......(i think i forgot some)
change filter,clean MAF sensor,air up tires,change spark plugs, PCV valve, and one of the MOST important drive NORMAL
Old May 27, 2010 | 06:45 AM
  #74
Rock-a-Lex's Avatar
Rock-a-Lex
Well, I do mostly (I guess around 70% or so) local driving and with my mods and heavy foot (at times ) I get around 14-16mpg. We ONLY have ethanol-infused gas here in NY. The gas SUCKS the big one! It's more expensive and doesn't burn as efficiently. The gov't really screwed us on this...the only reason why they did this is to keep the gas prices relatively stable but without giving the consumer pure gas...now (well, it's been several years now) it is a mix between gasonline and ethanol. So, this move allowed oil companies to make an even greater profit margin! lol...gotta love it.
Old May 27, 2010 | 08:50 AM
  #75
vwynn's Avatar
vwynn
2002 Lexus GS 300/GS 430
Sorted by MPG (city), Click on column headings to resort
Select up to 4 models to compare
Carbon Footprint
(tons/yr of CO2) Info
Air Pollution
ScoreInfo
All states except
CA and NE states
arrow
Estimated
New MPG
Annual
Fuel
Cost
Model
city hwy
Lexus GS 300/GS 430 6 cyl, 3.0 L, Automatic (S5), Premium
Lexus GS 300/GS 430
9.8
score = 02
16
city 23
hwy
$2454
Compare to Official EPA Window Sticker Fuel Economy
Lexus GS 300/GS 430 8 cyl, 4.3 L, Automatic 5-spd, Premium
Lexus GS 300/GS 430
10.4
score = 03
16
city 21
hwy
$2594
pulled from fuel economy.gov.
just be happy and drive.. if you want a fuel efficient car buy a 4 banger or hybrid.. or a car with long gears.
Retroplay
Apr 6, 2017 08:52 AM
CyBorG
Feb 9, 2007 07:22 PM
joedaddy1
Hybrid Technology
20
Sep 13, 2006 08:01 PM
Dinomon
Aug 23, 2006 08:47 AM
xaden
Feb 2, 2006 07:39 AM
