Gas Mileage Down The Drain
Old Sep 24, 2008 | 07:12 AM
  #46
vrferrari's Avatar
vrferrari
Originally Posted by shvc1991
Would upgrading to a higher amperage alternator help with this current draw issue?
No, if related to your mpg. A higher amperage alternator (if available for our cars) would only be able to GENERATE a higher peak amperage output, but the drag on the engine to spin the alternator would not change at peak output. A higher amperage would possibly secure the possibility that you don't have enough amperage available to fire your ingnition system while cranking your stereo.
Old Sep 24, 2008 | 07:24 AM
  #47
vrferrari's Avatar
vrferrari
Originally Posted by TruPlaya26
Well my lights don't dim as it is now, neither does anything else in my car. I have a brand new battery which may be the reason but I've always heard that caps are a waste of time and money, anyone on here using one with good results?
A capacitor is just another form for storing electrical energy, it does not itself create any energy but stores energy supplied to it by your electrical system. In this regards, a capacitor would only work for your stereo system in making sure it had enough clean power to continue to operate. The alternator still would have to supply the energy to the capacitor to keep it fully charged.
A capacitor is used in the car stereo world to supply that "boost" of electrical energy when the stereo goes into high amperage mode. It also is used to keep the voltage clean and stable. Think of it like a UPS system for computers....it keeps the electricity clean so that your stereo does not go into a "brown out" state. Brown out's for lights would make them dim, but for an electrical device that requires a minimum amount of electricty to turn on, ala a transistor, that device would turn off and on as the power fluctuates.
Old Sep 24, 2008 | 09:55 AM
  #48
L3XOTIC's Avatar
L3XOTIC
Tis is the problem with having a modded car. You lost control of MPG and too much upkeep.
Old Sep 24, 2008 | 09:59 AM
  #49
vrferrari's Avatar
vrferrari
L3XOTIC,
That's a pretty unique looking ride you have there. Do you have any better pictures of it, maybe posted in a gallery ?
Old Sep 24, 2008 | 05:40 PM
  #50
shvc1991's Avatar
shvc1991
^ Definitely unique. Looks bad *** with that black vinyl roof.
Old Sep 24, 2008 | 08:48 PM
  #51
kingkirby's Avatar
kingkirby
my fuel light just came on and i ran about 250k on a full tank and like a dollar top off... i have a heavy foot and road rage.
Old Sep 24, 2008 | 08:54 PM
  #52
shvc1991's Avatar
shvc1991
What's 250k? 250km? 190 miles?
Old Sep 25, 2008 | 03:00 PM
  #53
DINH300's Avatar
DINH300
I don't think it has to do with anybody having a system in there trunk. I had a system in my car I was checking up on it last week I was getting 12-14mpg city and 16-18 on highway.
3months before I left the country I notice that cheveron never uses ethanol in there gas but all the other gas station did. I notice that eveytime I filled up at a BP, Shells, Valero, Sonco, Mobil, or U gas, I would get crappy milage because 10% or whatever ethanol they mixed into our gas. So I continued to go to cheveron because I was actually seeing a defference. But when I got back to the states cheveron now mixes there gas with ethanol just like all gas stations.
Old Oct 14, 2008 | 06:40 PM
  #54
2slow4u's Avatar
2slow4u
Originally Posted by jcat_GS3
might i recommend fuzion HRi's 75 a tire, made by bf goodrich and theyre supposed to last 40k miles. All season tread but aggressive enough so you dont lose too much handling. A bit noisy on concrete highways but i'm looking forward to the snow because i think they'll grip just fine.
While i mean no disrespect in this comment, Fuzion tires are not made by BF Goodrich. While the BF is correct, its just not that company. ( http://www.allbusiness.com/automotiv...8689118-1.html ) Its made by Bridgestone/Firestone.
Now i'm curious; i know everyones driving habits are different, why are the mpgs so different and wild? Some seem as farf etched as the next.
Old Oct 14, 2008 | 06:57 PM
  #55
MJImport's Avatar
MJImport
basically stock '98 GS400 113,000 miles
I spent the last 2 weekends making the exact same trip, about 3.5 hours, large majority was highway. The first time I got about 19.5 mpg (forgot to check tire pressure). Before starting the same trip the following weekend I made sure to check the pressure and found I was running around 25 psi, so I topped off around 38 to 40 psi. The 2nd trip was a little more stop and go with slightly heavier traffic but still mostly highway, I was able to get around 21 mpg. I guess I can't complain but I had a similar 98 GS400 a few years ago that I swear I got close to 25 mpg highway, had the same amount of miles on it, both with 18's. I'm starting to believe that fuel quality is playing a part in the crazy sways in mpg observations.
Old Oct 14, 2008 | 07:18 PM
  #56
Rippaflow's Avatar
Rippaflow
Man my mpg has been horrible ever since i bought the car a year ago (GS430 btw). Even before when the car was stock I never got over 15 mpg in the city and that's driving under 3k rpm 95% of the time. On the highway though my best mpg avg. was 23. Now with my mods and system I'm getting about 13 - 14 mpg city and I'll figure my highway mpg this weekend when I go on my long vacation ... Maybe I seriously need a tb cleaning lol
I pedal to like 1700-1900 rpms in the city and rarely go above 2500 when merging on to the highway generally. That gets me my 22-25 in my 430. However when I tend to do the 2000-3000 driving that number quickly becomes 19.5-21. It's all about coasting in V8s. Get up to speed and take advantage of the fact torque isn't going to let you drop in speed immediately. .
Old Oct 15, 2008 | 11:37 PM
  #57
GS4_Fiend's Avatar
GS4_Fiend
wow, you guys are running your tires 35 and up? i have the OEM 16s and i run them at exactly 30 or 32. I know they can go higher but i just follow spec, i'm surprised you guys are willing to let go of some comfort for an extra 2mpg...
i got stock 17" rims running on pirelli p6 all seasons. I inflate them to 45 psi and they run stiff but nothing wrong and no problems.
Old Oct 15, 2008 | 11:42 PM
  #58
GS4_Fiend's Avatar
GS4_Fiend
Originally Posted by pingu
You should also take into consideration that you may get uneven tire wear if you increase the PSI in the tires.
Uneven tire wear not exactly. Depends how you drive as in taking hard turns and do your alignment you should be fine. I'm running on 45 psi on my tires for 1 year no alignment problem whatsoever
Old Oct 15, 2008 | 11:45 PM
  #59
GS4_Fiend's Avatar
GS4_Fiend
i got an 03 gs430. City and Highway together gives me 22 miles per gallon
Old Oct 21, 2008 | 06:05 AM
  #60
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
I forgot to post my new mpg when I got back from my trip ... I averaged 20 mpg !! wtf!! all highway on a trip to tampa and orlando just setting cruise control to 90 the whole way, this is a 3 mpg drop from when I didn't have the system installed
