Yes another muffler thread! X Y H or || pipe
I will be doing my muffler soon. I have the GS400. I can split the mufflers by adding a X, Y, or H pipe. I was thinking of just doing straight (||)pipes right to the stock mufflers. I know, I know! some of you will say "just get aftermarked mufflers...." I am thinking of keeping the stock look with just a louder sound.
I would like to hear from those who have done similar setup. what would be the best way to go? I am taking suggestions
Always wondered if we could go the straight piping route with the Tanabe Medallion Touring Cat-back system? what would be the pros and cons of that setup? Would X-pipe work better with this setup?
Originally I wanted to remove were the muffler pipes meet and take them straight to magnaflow mufflers. I think that is the less restrictive setting. Better thank x y or H pipe. The only thing that worries me is will it be too loud? Not that I mind. I guess that is why I will probably just do the straight pipes to the original mufflers. If it sounds good Ill keep, but if it does not make too much of a difference I will probably go magnaflow mufflers.
I have been searching for sound clips of straight pipe with muffler setup for the gs400's I don’t seem to find. The links I find are no longer there.
If you run separate dual pipes you will loose torque and make your engine sound more like a mustang.
If you want to gain power and or achieve a specific sound you should search and read as much as you can as there are many that have posted results.
The reason the factory Y pipe works so well is that it works like a one way valve letting exhaust flow away from the engine without providing much restriction. If you take off everything except the Y pipe and do a pressure test you will find minimal backpressure at full throttle at redline. At less than redline you will be hard pressed to find any backpressure.
You have a heavy car with a small 4 liter engine. Low speed torque is important to how much fun the car is to drive. Things like a torque converter upgrade, 3.76 gears and headers will all make the car FEEL so much better. Exhaust changes will change the sound and frequently to a less desireable sound.
So, what do you really want?
There is a reason why headers/exhaust manifolds are built the way they are. Imagine having 8 individual exhaust piping for your car. You can bet the car will drive like **** around the city.
You will not limit the flow as long as the collector is well design so it doesn't become a bottleneck.
Feedback?
jumpboy023
Jan 6, 2008 06:43 PM
1badceli
Jan 11, 2006 12:30 AM
