Any point in getting high flow converters????
Old Feb 17, 2008 | 08:42 AM
kevs98GS4's Avatar
kevs98GS4
Question Any point in getting high flow converters????
I was thinking of getting some high flow converters for my 99 GS4......but my question is......is there any point in doing this on our cars? do we have high flow converters from the factory?? will there be any hp gains from this mod?? I have talked with a local company that makes the best aftermarket converters and they will make me some custom ones for about $200 ea. that will direct bolt up. Should I spend the money? I'm not a fan of wasting it!!!!
Old Feb 18, 2008 | 10:46 PM
pimplux808's Avatar
pimplux808
i never heard of the gains on our gs4's but i know when i had my integras i would take the oem 1 out and put a high flow cat inside .. it made a huge difference ..now u got me thinking if i should put one on the gs4 now
hmmMMmm?
Old Feb 18, 2008 | 11:10 PM
Balling's Avatar
Balling
two words
test pipe
Old Feb 20, 2008 | 08:34 PM
JBrady's Avatar
JBrady
The stock GS400 cats are very high flow. Leave them alone.
Old Feb 21, 2008 | 07:18 AM
NiteOwl's Avatar
NiteOwl
Originally Posted by Balling
two words
test pipe
Two more important words: Federal offense.
If you get caught driving a car in about 46 of 50 states w/o a cat, it is a federal offense, punishable by jail time. The car will get impounded and if a mechanic did the swap they can get in big **** trouble as well.
Bottom line: Not worth the risk...
Old Feb 21, 2008 | 07:27 AM
kevs98GS4's Avatar
kevs98GS4
I wasn't going to delete them!!!!!!
Old Mar 17, 2008 | 12:45 AM
G430's Avatar
G430
Default aftermarket high flow cat converters
yeah i've been searching around to see where can i get after bash converters cause i believe mine are toasted... like o2 sensors been replaced and the tech told me to get new cats... i am very clueless...
Old Mar 17, 2008 | 04:09 AM
JeffTsai's Avatar
JeffTsai
What if you can gain 60-70hp from removing the cats? Would it be worth it then? A ton of high horsepower turbo guys run catless because it is that much of a restriction at those power levels(high as in 500-600hp+ range).
I have an exhaust dump. I can run through the restrictive exhaust when need be for quietness and legality. When I need to lay down the law, I just open the dump and all hell breaks loose. So loud you can hear me a mile away, gain a very good chunk of power, and exhaust dumping out 4ft after the turbo of EPA goodness.
Old Mar 17, 2008 | 04:16 AM
bg_281's Avatar
bg_281
I say fu<k the law, I hollowed out my cats and put o2 extensions on so I wouldn't set off a cel.... that's right straight pipe all the way!!!
redliner8
Mar 24, 2024 06:56 PM
2012IS250
Sep 1, 2014 12:27 AM
LexISguy
IS F (2008-2014)
Feb 25, 2010 11:43 AM
D1GP
Dec 5, 2007 09:22 AM
nysupraman
Jun 29, 2005 01:12 AM
