mazzuri super headers
Old May 29, 2008 | 08:47 PM
  #751
GSteg's Avatar
GSteg
Soldering isn't used too much in aircrafts because of vibrations. Over time, your solder joints can stress and crack. You definitely do not want this while flying. However, that is not to say that there is absolutely no soldering on aircrafts. Solder can be used in on multi-pin connectors, but I dont consider that connection to be the same as two joining bare wires. Most of the time, you'll see wires being crimped.
Though for cars, I wouldn't worry too much about it. If I have to solder, I usually double up on the heatshrink.
Old May 29, 2008 | 09:50 PM
  #752
mazzuri's Avatar
mazzuri
Originally Posted by 08mica
No pics. but guess what brown did for me today?
Tomorrow, took the day off to go dyno, install, ant wait 500 miles.
BTW I hate Brown. If I could tell the stories of thenumber of times thye screwed my stuff up. I just don't know. I don'tt evenship often.
BTW, 500 miles is not the magic number, it can be any number of miles, it's really in how you drive it.
Old May 29, 2008 | 10:03 PM
  #753
Lextasy89's Avatar
Lextasy89
hmm what is the magic number then??
Old May 29, 2008 | 10:22 PM
  #754
lobuxracer's Avatar
lobuxracer
Tech Resource
Not since 1992. You can't even order a solder cup Cannon plug for an aircraft application in the Air Force. All crimped pins, no solder. The only solder allowed is on PC boards. Not one drop of solder on a wiring harness anywhere.
How do I know? I needed to replace a solder cup Cannon plug on my jet and I couldn't order it. I was told they are superceded by the crimped pin models. I checked the T.O. and it said no more solder anywhere on an aircraft harness. It's unreliable. So I got to crimp 105 pins. Lovely.
Old May 29, 2008 | 10:45 PM
  #755
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by Gernby
I would be interested in reading why soldering would be a bad thing. Although I'm not in the industry anymore, my Bachelor's degree is in Electronics Engineering Technology from Texas A&M University, and I can't think of any reason why soldering the connections wouldn't be good. However, I do agree that with the right equipment, connectors, and pins (very rare), modifying the harness by removing the OEM pins and recrimping new wires and pins would be cleaner.
Originally Posted by mazzuri
1st time in my life I am reading that soldering the wire harness is a bad idea. I have done it all my life, every one I know has done it all their life, some people who only install motecs and haltecs only solder and do not trust anything else (as do I), never ones had an issue and only read about people who have issues with the quick connect things. I would only solder, I don't feel comfortable using something that may come apart, no matter who or what certified it.
The only mistake people make with soldering harnesses is they don't do it right, and don't unplug the harness before soldering and a lot of times fry the stuff inside.
Here's the problem in a nutshell - solder wicks up the wire underneath the insulation. So does the flux. Both of them create stress points in the wire, and when the wire is subjected to vibration (any aircraft/automotive/motorcycle application) it will crack underneath the insulation and fail. The wire will appear normal but it will not conduct. So you spend many hours troubleshooting a failure that is actually a wire failure you cannot see.
If this happens to be on a critical system that isn't redundant, you're in serious trouble with aircraft.
Some Air Force MPTOs (methods and procedures technical orders) are listed here. 00-25-234 covers electronics standards including soldering, 00-25-233 covers integrated pressure systems. Both have a LOT of information on workmanship standards and design information for repair technicians.
Old May 29, 2008 | 10:53 PM
  #756
GSteg's Avatar
GSteg
Not since 1992.
Do you know if this rule applies only in America? I know that Microair in Australia has a small section in their literature where they talk about using solder in their multi-pin connectors. The literature was created in 2006. Perhaps they haven't caught on yet.
Old May 30, 2008 | 06:42 AM
  #757
Gernby's Avatar
Gernby
Originally Posted by Giggity
No, I really do understand, I have had a few N/A cars that I threw a lot of "good" bolt-ons at with nominal results, it wasn't until they got a good ecu tune on a dyno did the car really respond to any of those "good" bolt-ons.
When tuning nearly stock N/A applications with basic intake, header, and exhaust, the goal is always to pull out excess fuel, and maybe optimize timing. When totally stock, there is considerably more excess fuel that needs to be pulled, so a good tune on a stock car will net significant results. As you add "good" bolt-ons, there is less excess fuel that needs to be pulled, so the net benefit of the tune will be less significant. That's why I said you don't understand. You would have gotten even better net gains from tuning BEFORE adding the bolt-ons. Basically, it just isn't right to say that headers won't work right without a tune, since the tune really has nothing to do with the headers.
Old May 30, 2008 | 06:43 AM
  #758
Gaugster's Avatar
Gaugster
I can agree with the idea that crimped type connections are better (more reliable) the solder type connections.
It is well known in the Automotive industry that a ‘gas tight’ seal made by a solid crimp is all that is needed.
Also, to use a fancy word, it is easy to anneal the copper wire when applying the heat needed to make a solder connection. This makes the wire more brittle and could result in a field failure under harsh conditions.
However, it is easy to go overboard with this stuff. I have made many solder type connections for various harnesses (Car & Motorcycle) and never had a failure like the type mentioned. Knowing all this, I still used solder connection and always do my best to apply as little heat as needed.
Here is how I installed the SIM for reference.
Old May 30, 2008 | 06:45 AM
  #759
Gaugster's Avatar
Gaugster
Completed view
Old May 30, 2008 | 08:58 AM
  #760
mazzuri's Avatar
mazzuri
1234189032901734523509810986124862345908265098265 miles... I have no idea.
Old May 30, 2008 | 09:04 AM
  #761
Lextasy89's Avatar
Lextasy89
well then 500 is close enough to the magic number.... bc the ecu should definately have time to learn the increased airflow by then.. and if not then its never going to and will need tuning
Old May 30, 2008 | 11:31 AM
  #762
iSuxeL's Avatar
iSuxeL
OMG, this whole time I thought the "SIM" was like a fouler or something. So when buying a set of these headers, will there be a guideline on which wires to solder?
Old May 30, 2008 | 11:52 AM
  #763
Gaugster's Avatar
Gaugster
Nope, you just have to guess. Choose but choose wisely.
Kidding. Instructions are included so it is not a big deal. Of course, don’t forget that it is probably illegal if anyone cares.
Regards,
Old May 30, 2008 | 12:15 PM
  #764
Giggity's Avatar
Giggity
Yeah, but it has been my experience that most obdII computers "learn" and no matter what bolt ons you add to increase flow both in and out of the engine to lean out the air/fuel mix, the computer will adjust to keep with the parameters of the rich setting determined by the manufacturer.
I didn't say the headers won't work, dyno sheets have already shown some o.k. gains, I just don't think it's cost effective to throw bolt ons at a motor that as of yet cannot be tuned to optimize performance.
What good does it do to optimize flow out of the engine, if you can't optimize flow and fuel mix going in, this has just been my experience with 2 liters or less of displacement, so I may be a bit off base with with an engine of larger capacity.
Old May 30, 2008 | 01:10 PM
  #765
carchitect's Avatar
carchitect
I know what Daniel is trying to say here.
The OEM ecu will run the emissions tests whenever the monitor criteria has been met. If its running the test and the criteria has changed (like full throttle acceleration, the vehicle is shut off,etc.) the test is aborted and retried once it has been met again. These are CARB regulations and ALL manufacturers have to follow them (even though most US manufacturer's cars I've seen happen to fumble these tests up and they don't get their hands slapped)
