Throttle Body Coolant Bypass
Old Oct 31, 2007 | 04:10 PM
VNN326's Avatar
VNN326
Default Throttle Body Coolant Bypass
i was wondering if this really works? i drive a gs3. i was going to try to do it for my car. but im just seeing if its worth bypassing?
http://bananags.grantham-internation...oolant_bypass/
Old Oct 31, 2007 | 09:11 PM
Lexizm's Avatar
Lexizm
I've done this mod and it's not hard at all. Just don't look to gain any additional hp.
Old Oct 31, 2007 | 09:16 PM
pimplux808's Avatar
pimplux808
what does it actually do ?
Old Oct 31, 2007 | 09:19 PM
pimplux808's Avatar
pimplux808
ok i jus read what it does.....i dont think i need to do this because i live in hawaii............the hottest it gets is like 95 degrees and the coldest is like 65 degrees.......
Old Nov 4, 2007 | 10:28 PM
EvolvedGS3's Avatar
EvolvedGS3
The coolant line going to your throttle body is designed to keep the throttle body from becoming frozen or stuck due to very very cold weather.
This is a very common DIY mod. By rerouting the coolant line from the throttle body you will keep the 180 degree coolant from heating the intake air.
If it doesnt get under 20 degrees where you live, then I would consider this mod. If you do really have a winter then keep it connected.
I have heard of people gaining around 2-3 HP from this. But keep in mind our throttle bodies are routed directly over the head (GS3), heat soak will probably keep the temp of the throttle body in the same range as the coolant would. So you are probably wasting your time.
my .02 cents
Old Nov 6, 2007 | 01:58 PM
VNN326's Avatar
VNN326
i was wondering, if i do a coolant bypass, that means i use more coldair. So doesnt that mean i use more gas?
Old Nov 12, 2007 | 09:16 AM
ElitistK's Avatar
ElitistK
only if your foot is heavier.
and don't waste your time with this mod. there's no point in doing a bypass when your TB sits on top of the engine.
Old Nov 12, 2007 | 09:42 AM
VNN326's Avatar
VNN326
lol figures. thanks
Old Nov 14, 2007 | 06:04 AM
JeffTsai's Avatar
JeffTsai
I did it simply because those 2 extra hoses are a pain when changing spark plugs or working on the engine and you need to remove the throttle body. I was always tinkering with something on the engine all the time. Also, I have to change spark plugs every oil change 4-6k miles on my car. Performance plugs for a boosted motor don't last long lol.
Old Nov 14, 2007 | 07:15 AM
VNN326's Avatar
VNN326
lol thats insane, but you have a nice car jeff. i think its worth it
06350F
Apr 7, 2014 01:08 PM
marosekcmo
16
May 7, 2012 10:18 PM
white ice
Jul 23, 2005 05:56 PM
matt7184
Nov 22, 2001 08:46 AM
