swap::aristo 2jz ???
Old Nov 2, 2006 | 03:01 PM
cino78h's Avatar
cino78h
Default swap::aristo 2jz ???
hello i got an GS400 i was just woudering would an Aristo 2jz fit in my GS400 or should i sell its and buy an GS300???..if so what other things would i needs to make its work..ECU harness etc.
thanks-
Old Nov 2, 2006 | 03:16 PM
bighitbike's Avatar
bighitbike
You CAN do it but it will be way harder then trying to do it in a GS3. If you are serious about doing it I would just pick up a GS3 and do it in that instead.
Old Nov 2, 2006 | 09:10 PM
cino78h's Avatar
cino78h
would the motor mount line up???cuz i can alway switch what ever an GS300 has to make an ARISTO motor work??i know that its would need an v6 harness?but what if i switch all of my harness to an GS300?
Old Nov 2, 2006 | 10:18 PM
lalexusgs's Avatar
lalexusgs
I can switch with you if you decide to pick GS3 for your GS4
Old Nov 3, 2006 | 06:56 AM
GSoup's Avatar
GSoup
CL Folding 10,000
Motor mounts are different.
Direct drop in on a GS300.
Old Nov 13, 2006 | 08:06 AM
cino78h's Avatar
cino78h
but can its be done??i used to weld and chop honda cars=P...how abouts an LEXUS???
Old Nov 13, 2006 | 08:36 AM
thanhvu's Avatar
thanhvu
....look at the post directly above you...
Old Nov 13, 2006 | 09:35 AM
GSoup's Avatar
GSoup
CL Folding 10,000
let me clarify that.. Aristo 2JZ 1st gen (JZS147) needs work on the motor mounts for it to work in a 2nd gen. (Bluelex has a 1st gen 2jz in a 2nd gen GS). 2nd Gen Aristo (JZS161) is a direct drop in for the gs300. (BurgundyGS and several other members have this setup).
here's some additional info:
https://www.clublexus.com/forums/sho...d.php?t=219749
Just use the search function and you should find additional info on it
Old Nov 13, 2006 | 10:41 AM
mikal's Avatar
mikal
Dont waste a GS400.. trade it for a GS300.
and be sure to get a FULL front clip of the jzs161. Too many headaches with just a motor set.
estomax
Sep 23, 2013 11:53 AM
xspsi6
Jan 9, 2012 07:59 AM
sc400123
Performance
May 7, 2009 11:25 AM
