Need Help SRT intake check engine light-0172 code
Old Aug 23, 2006 | 06:38 AM
solow24's Avatar
solow24
Default Need Help SRT intake check engine light-0172 code
First I want to thank Forrest & Ben at Exact Performance, they really took care of my car when I was in MO,and told me about this site . However,I've relocated to GA (ATL) and am in need of someone to work on my 98' GS300 with a SRT-cold air intake. Reason? Check eng light, code reader shows 2 codes, 1. 0172, bank 1, 2. 0172, bank1 pd (pending). Dealer can't find anything wrong with anything . O2 sensors,hoses,ambient outside temp, evrythings fine. Replaced plugs. Wiring for new ECU resoded per SRT specs. SRT said if I bring the car to Maryland they would figure it out(500 mile drive). With Georgia emission testing ,I was able to drive it 200 miles after resetting the ecu for a good reading on the states testing, and get my tags. Can anyone help me? I can erase the codes with my reader,but after driving for a bit, check eng returns, performance is lousy. Some days I can drive it all day without the chk eng light coming on, others not. Also,I want to thank Scott, for all he has done . I'm in desperate need of help and info!!
solow24
Old Aug 24, 2006 | 01:59 AM
#1gs300's Avatar
#1gs300
the only thing that i can tell u if ur getting codes for ur o2 sensers and u get the codes to erase by resseting ur ecu, or using an obd11 scanner to erase the codes than it got to be the senser itself, the way i found out i was burning more fuel than i normally did i hope this helps.
Old Aug 24, 2006 | 05:41 AM
solow24's Avatar
solow24
Default Thanks Kenny
Thanks 4 the heads up ! The dealer replaced all the o2 sensors, found out nothing wrong with them, put the old ones back on.
did not want to throw money away for nothing! They had it last week, same thing, they only got the 172 running rich codes, no other code. Told me don't waste my bucks on the o2's.
Vishuz
Nov 17, 2011 05:58 AM
russ29
Dec 11, 2009 03:58 PM
cilverlex
Performance
Aug 19, 2008 06:01 PM
GS FONZy
Performance
21
Jan 31, 2007 05:34 PM
David GS400
Performance
Jul 29, 2004 12:29 PM
