Timing Belts and potential for damage
Old Jul 20, 2006 | 12:58 PM
BA_GS400's Avatar
BA_GS400
Default Timing Belts and potential for damage
If my timing belt was to break when I am tooling down the highway, would I incur engine damage? (or does the engine do that "free-wheel" thing)
Old Jul 20, 2006 | 01:03 PM
ILOVEGIRLS's Avatar
ILOVEGIRLS
your pistons may smack you valves and you may bend them or break them resulting in the worse case senario or you can be super lucky and nothing goes wrong. there are tons of variable to get into but those are the main cases.
Old Jul 20, 2006 | 01:28 PM
Dx3's Avatar
Dx3
I thought the GS400 had an interference engine On that basis, yes it would more than likely do some serious damage.
Jonny
Old Jul 20, 2006 | 02:57 PM
BA_GS400's Avatar
BA_GS400
Originally Posted by ILOVEGIRLS
..... there are tons of variable to get into but those are the main cases.
Please explain....what are the variables?
Old Jul 20, 2006 | 03:46 PM
Dx3's Avatar
Dx3
http://www.familycar.com/CarCare/TimingBelt.htm
Jonny
Old Jul 20, 2006 | 09:43 PM
BA_GS400's Avatar
BA_GS400
Question
Dx, thanks for the link man. I know you're trying to help.
I'm very, very familiar with engines. Know each part, replaced most of them, set my own valves on the standard chevy and ford engines of old, rebuilt untold carb's, replaced heads, tranny's, TQ's, engines, etc.
I actually have a 69 Camaro RS that I'm building now too. Pics will show up here for that one day.
Your reply and the story in your link did have a sentence that summed up my question in new verbage though, that was cool.
"There are two types of engines that use timing belts. They are described as: "Interference Engines" and "Non-interference Engines".
Which do we have? That is the question.
My tongue-in-cheek reply about the variables was just bait. I do not believe there are any variables here. I set the parameters in my original post....."tooling down the highway". ie. no load, high rate of constant speed, BAM- belt breaks.
Sure, there are variables to *DETERMINE* if you have an interferance or non-interferance engine, but, that wasn't the question, so, I wanted to see how "variables" fit into my original post.
BTW, that's a great link you put up. Seriously.
Old Jul 20, 2006 | 09:55 PM
BA_GS400's Avatar
BA_GS400
All this talk of "interference" reminded me of a time I was whipping around town here locally in that same 69 Camaro RS mentioned above.
I pulled away from a light pretty quickly one time and then heard a god-awful noise, with a subsquent "miss" in the engine. I also noticed that the power wasn't there as much, it sounded bad. Gave me that wrenching, knotted feeling in the gut, ya know?
I pulled over, popped the hood, looked around. All looked ok. I pulled off the valve covers (T-handles used on studs) and BAM, there was a floppy rocker and a piece of a broken chrome-moly pushrod!! Whoops!
I grabbed the broken pushrod and drove home........very carefully.
Old Jul 20, 2006 | 10:02 PM
Dx3's Avatar
Dx3
https://www.clublexus.com/forums/sho...t=interference
From this link TLW said that the GS300 and GS400 are both interference engines.
Jonny
Old Jul 21, 2006 | 12:08 PM
BA_GS400's Avatar
BA_GS400
EXCELLENT FIND Dx3!!!! Thanks for that. I really did want that "positive, absolute" kind of answer. Looks like you found it!!
TLW sure knows his sheet!!
THANKS!
Old Jul 21, 2006 | 12:39 PM
Dx3's Avatar
Dx3
THANKS!
Glad to help man.
Jonny
Old Jul 21, 2006 | 01:32 PM
GS300t's Avatar
GS300t
I have no clue about the 400, but everyone seems to agree that it is an interference engine. As for the 300, I'm pretty positive that it is non-interference as TLW states. Later on someone says they think they're both interference, but I'm pretty sure the 300 is not. Not that you care since you have a 400, but thought I'd clarify all info given.
AlaskanLS
Nov 9, 2017 10:36 AM
esaloum
Jul 16, 2010 10:13 AM
pienomiko
Maintenance
Mar 10, 2009 06:48 PM
jaycin702
Mar 28, 2008 01:35 PM
SuperCoupe400
Jan 4, 2008 11:39 AM
