supra differential
Old Mar 21, 2006 | 03:19 PM
wgs400pr's Avatar
wgs400pr
Default supra differential
How many types of diff are they for supra . I got mine today ,it dos not look like any i have seen on the site. is there only 1 tipe of lsd and 1 tipe of open diff.or is ther anoder one.
Does the gs400 diff look like the non lsd supras.
Old Mar 21, 2006 | 05:27 PM
JeffTsai's Avatar
JeffTsai
Post up a picture of it. Might help others in tying to figure out what it is. Also, it would be a good idea to get a pic of the model number stamped on the tranny.
Old Mar 21, 2006 | 08:19 PM
TLW's Avatar
TLW
auto
auto with LSD
6 speed ??with LSD ..not sure
www.mkiv.com
Old Mar 21, 2006 | 08:21 PM
wgs400pr's Avatar
wgs400pr
Ok i purchest a rmm 3.76 lsd for gs400 on ebay ,I took the cover out to see if i got the reel
thing . what i found is that it is defrent than the gs one but it does not look like the
supras torsen i have seen on the site. did the supra have two difrent types of lsd,
I red that from 97 up they changed two helical lsd.
Old Mar 21, 2006 | 08:24 PM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
The RMM LSD is the Supra LSD, no difference.
You either have a Supra LSD or a Supra W/O LSD.
Do you have the item # it was assigned on Ebay? Sometimes you can still look up the original sale item.
Show us a pic and we can talk more.
Old Mar 21, 2006 | 08:28 PM
TLW's Avatar
TLW
Question
FRom 93-95 auto TT definitely had LSD, all other years it was an option
Does the casing have cooling Fins ?
Old Mar 21, 2006 | 08:31 PM
RMMGS4's Avatar
RMMGS4
Yeah like this?
Old Mar 21, 2006 | 09:11 PM
wgs400pr's Avatar
wgs400pr
It does have the cooling fins on the top and in the bottom. I was looking around and found a picture of a (type 2 torsen lsd) that came whith the supra on 96-97 and it looks like the one i have. and it has 49 tooth in the ring gear. doeit make sence.
Old Mar 23, 2006 | 02:08 PM
wgs400pr's Avatar
wgs400pr
Apparently i got the reel deel I installed the diff today, wow what a difference any way thank for the replys.
Old Mar 23, 2006 | 02:19 PM
RMMGS4's Avatar
RMMGS4
Great
Yeah the car should just pull hard in all gears and punching it coming out of a turn you will be able to get on it hard without the inside tire spinning.
Funny thing is you probably knocked a few tenths off of you 0 - 60 times, but technically no HP gain from stock.
XxPainxX
Sep 2, 2011 10:48 PM
MrMilo
Performance
May 20, 2006 10:16 AM
modifyd
Performance
Feb 21, 2006 07:56 PM
lex400sc
Oct 28, 2004 03:13 PM
