IS350 Turbo???
Old Oct 17, 2005 | 06:51 PM
FastIS350's Avatar
FastIS350
Question IS350 Turbo???
Are there any turbo kits available for the IS350? If so what are they performance gains and anything else.
If no turbos out what about superchargers? Thanks
P.S. this is my first post, so if there is info on this site anywhere about this please give me the link.
Old Oct 17, 2005 | 07:25 PM
Badman Forever's Avatar
Badman Forever
nope, but i wouldn't mind seeing a stroker kit bumping up the displacement to a 4.0L V6. chances are the is250 would be boosted before the is350.
LexFather
Guest
Posts: n/a
Welcome to Clublexus. I suggest you use the SEARCH feature, as you would have found your answer.
1. No kits turbo or S/C available.
2. I doubt it will happen ANY time soon b/c
A. High compression ration
B. Trickier ECU
C. Dual VVTi
The car is a techno marvel. It will be tougher and tougher to just slap F/I in cars today and of the future.
Old Oct 18, 2005 | 06:12 AM
BaLLzZz's Avatar
BaLLzZz
Whats up sick quick question. What si the compression ratio on this new 6 because i know my tl is 10 to 1 so no FI their esp fwd. But its not higher than 10:1 right?
Old Oct 18, 2005 | 06:51 AM
jlin101's Avatar
jlin101
if IS350's 306hp is not enough to satisfy your appetite, there is a higher performance variant (the rumored IS500) down the road to go against the likes of M3 and S4.
Old Oct 18, 2005 | 09:53 AM
cooney's Avatar
cooney
Default compression ratio
According to Road & Track, the compression ratio of the 3.5 liter engine in the IS350 is 11.8:1
cooney
Old Oct 18, 2005 | 09:56 AM
LexFather
Guest
Posts: n/a
cooney
BaLLzZz That is correct.
Old Oct 18, 2005 | 10:03 AM
Arizona's Avatar
Arizona
11.8:1 damn that was higher than my type-r. You could prolly throw on bolt ons and cams for some sweet all motor madness. Imagin popping the hood and seeing ITB's on a lexus
Old Oct 18, 2005 | 10:10 AM
LexFather
Guest
Posts: n/a
I think its going to be even tougher for tuners to crack the ECU. Hello super dooper piggy-back
Old Oct 18, 2005 | 12:28 PM
spwolf's Avatar
spwolf
I have no doubts that within 1 year you will be able to get Turbo kit with piggy back ecu like Emanage. If stock 2zz with higher compression ratio and 4cly engine can be boosted safely, no reason for at least IS250 not to.
And since it is released in Japan as well, I bet there will be kits from there for IS350 at least...
Old Oct 18, 2005 | 12:36 PM
RCFormante's Avatar
RCFormante
Supercharged!
Turbo? Doubt it because of VDIM...
Old Oct 18, 2005 | 12:45 PM
spwolf's Avatar
spwolf
and VDIM will? VDIM has absolutly nothing to do with turbo, and it is a LOT LESS obtrusive system than TRC and VSC on older Lexus's which could not be turned off either...
Old Oct 18, 2005 | 02:53 PM
LSs1Power's Avatar
LSs1Power
With that high C/R i think headers, exhaust, light weigh pullies, cams, ported heads and intake manifold, larger TB, tuning and 75-100 wet shot of NOS is the way to go. These mods should put the car around 350HP N/A and 450HP on NOS.
cantinoz
Mar 29, 2021 03:18 PM
juice14
Feb 9, 2020 01:31 AM
choover
Jan 5, 2019 12:58 AM
Bakewalk
IS F (2008-2014)
51
Dec 20, 2014 01:30 PM
phlog
Performance
39
Oct 21, 2009 11:50 PM
