Tranny Leak!!!!!
Old Jul 27, 2004 | 07:26 PM
dagr8tsthustla's Avatar
dagr8tsthustla
Default Tranny Leak!!!!!
Okay....well I have a 98 GS300 with 115k....I just recently discovered that I have a slight tranny leak and it appears to be the seal??? That's what my mechanic told me...but he doesn't deal with tranny's and he wont touch it...Where should I take my car??/How much do you think it will run me???Should I just get the parts from Steve Ganz and take it to a local tranny shop here in NY??? Anyone know of any places in NYC I should take it to????
Please help!!!!
P.S. My fluid level hasn't dropped.....I check it daily and still no change...yet I leave a puddle every where I go and there is fluid dripping from the front end!!!!
Thanks in advance for any help!!!!
Old Jul 27, 2004 | 07:31 PM
D2-AUTOSPORT's Avatar
D2-AUTOSPORT
Former Sponsor
Danny, call 718-850-5000, its a shop on jamaica ave, it belongs to a CL member's brother. Ask for Mike and tell him you know Gazi with the turbo lexus
later
Old Jul 28, 2004 | 06:38 AM
dagr8tsthustla
Thanks D!!!! I should've just called you up first....I took it to my mechanic..remember the guy in LI??? Well he said it looked like the seal...but he just will not touch that tranny..I feel better that he told me no instead of saying....mmm...ummm....yeah...we can do it!!
Thanks Again!!!
Old Aug 5, 2004 | 01:00 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Front input shaft tranny seal =BIG $$$$$$$$$ to replace as the trans must come out for access.
Rear output shaft seal=much less than above as only the driveshaft needs removal. Most likely the rear seal. Couple hours of labor with $15.00 for the seal and replacement fluid.
Cross you fingers.
Lee
Old Aug 10, 2004 | 10:42 AM
dagr8tsthustla
Thanks!!!!!
Has this happened to you??? Well when my mechanic put it on the lift he said it was the front seal that needed to be replaced...so I'm in for it....
Danny
Old Aug 10, 2004 | 11:03 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Originally posted by dagr8tsthustla
Thanks!!!!!
Danny
Since he is in there, put in a new performance torque converter. Wont cost you any more labor.
Lee
Old Aug 10, 2004 | 12:08 PM
dagr8tsthustla
ha!!!!
I have no kind of engine work to my car....I won't need anything else to make this thing work????!!!!!
Old Aug 10, 2004 | 03:10 PM
JPI Racing's Avatar
JPI Racing
Front pump seal or rear main seal?
JPI
Old Aug 10, 2004 | 09:30 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
ha!!!!
Since it is the front seal, the trans must come out to replace it which means the torque converter comes out as well. Might as well put in a performance torque converter. Other than maybe walking 10 feet to a shelf to retrieve it at the shop, there is no additional labor involved so they should not charge you anymore.
Lee
Old Aug 11, 2004 | 07:15 AM
dagr8tsthustla
JPI
Well from what he said its towards the front....as far as that I would not know whether it is the Front Pump Seal ot the the rear main seal....Could you tell by looking at where the leak is coming from or do I just have to take it in to a tranny shop to be sure??? Is this a common thing JPI?
Old Aug 11, 2004 | 07:43 AM
JPI Racing's Avatar
JPI Racing
If you see tranny fluid, it's the front pump seal. If it's oil, then it's the rearmain seal. Btw, there is a seal in front of your engine called front crank seal. Make sure you ask him which one it is.
JPI
Old Aug 11, 2004 | 07:49 AM
dagr8tsthustla
THANKS!!!
Too bad you are not closer to me so I can have you do the work....I'm seeing tranny fluid...little spots here and there...it's comming from the front so it could be that front pump seal you mentioned....any idea as to an estimate of how much it will cost to fix??? Just so I can put a pillow under my chin when i get the bill!!!!!!!
Old Aug 11, 2004 | 10:22 AM
JPI Racing's Avatar
JPI Racing
If it's the front pump seal, He has to removed the tranny to replace it. I would ask him to replace your rear main seal while he is at it. This job will run you around $500-$800 at an Independent shop. Around $1000 and up at your local lexus dearlership.
JPI
Old Aug 11, 2004 | 01:09 PM
dagr8tsthustla
Thanks JPI!!!
I figured it would be about that...There is a local shop around here that other CL members have recommended that the owner worked at Lexus as a Cert Tech for 5 years....that gives me some sort of comfort...I guess I should do the tranny flush at the same time...what fluid would you recommend??? Any addtl parts/seals I should change while he is in there aside from the two you've already mentioned???
Danny
n8doggdago
Oct 10, 2008 05:51 PM
JM5879
RX - 1st Gen (1999-2003)
Feb 19, 2008 04:35 PM
tightlinez
Feb 11, 2008 06:34 PM
tommyGS3
Performance
12
Jan 29, 2005 12:59 PM
DaizenLex
Jun 23, 2003 08:42 PM
