:::QUICK, NEED HELP w/ LSD:::
Old Apr 23, 2004 | 01:39 PM
CJGS4's Avatar
CJGS4
Default :::QUICK, NEED HELP w/ LSD:::
Hey, I was in the market for the purchase of a 3.76 LSD rear end for my GS400. I found one off of a Supra '97 TT, and it is the entire rear, however I wanted to see if anyone knows whether or not this will fit, and if this is the part that I want?
Old Apr 23, 2004 | 01:48 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
I don't know the answer, but I suspect the person that does will ask you to post the part numbers stamped on it.
I've also read that you can't tell if it is a true LSD pumpkin unless you crack it open and look at the gears.
Old Apr 23, 2004 | 01:53 PM
CJGS4's Avatar
CJGS4
Default :::need Help With An Lsd::::
I am looking to purchase a 3.76 Rear end w/ LSD from a '97 Supra TT, but I am not sure if this will fit properly on my GS400. I am told by the seller that this is not a TORSEN LSD? What LSD is it?
Here are images...
Old Apr 23, 2004 | 02:16 PM
DaveGS4's Avatar
DaveGS4
Do you know for a fact if it is an LSD diff at all? Lots of supras came with those gears WITHOUT LSD - just an open diff.
PS, I merged your two threads... you only need one.
Old Apr 23, 2004 | 03:54 PM
HI98GS's Avatar
HI98GS
The pumpkin will fit as a direct replacement. It is the same as the RMM stuff. The only thing, like DaveGS4 mentioned, is that you gotta find out if it has an LSD. If the mechanic or whoever you are buying it from says it doesn't have the Torsen LSD then odds are that this is and open differential. The gearing is kick a## but you will likely just spin one wheel on hard launches.
Old Apr 24, 2004 | 04:01 AM
CJGS4's Avatar
CJGS4
I do know it's off an automatic Supra TT, does this mean it's not with an LSD?
-Chris
Old Apr 24, 2004 | 07:56 AM
DaveGS4's Avatar
DaveGS4
-Chris
Chris, the problem is I think the auto Supra TTs could come both with and without a LSD.
Old Apr 24, 2004 | 07:59 AM
johnee78's Avatar
johnee78
Exclamation
from what has been posted on previous posts about this matter, a majority of the rearends from 97-98 are 3.76 but are not lsd..here is a web page that can explain more in depth.Just click on RMM/SUPRA TT for more info..
http://lexusmodz.netfirms.com/
BTW-If you want to sell it drop me a PM...
INCLINEDI
Jan 22, 2012 11:22 PM
XxPainxX
Sep 2, 2011 10:48 PM
djpauldc1
Oct 29, 2010 12:28 PM
wgs400pr
Performance
Mar 23, 2006 02:19 PM
