Directions on how to flush radiator?
Old Jan 21, 2004 | 10:29 PM
disc108's Avatar
disc108
Default Directions on how to flush radiator?
Is this correct?
1) Take off radiator cap. Open valve at bottom of radiator that has a hose attached to it. Drain. I heard there were 2 other valves?
2) Fill with distilled water. Should I recap radiator cap? Run car with heater on full. Then drain again. Do this at least 2 times.
3) Fill with coolant. Run car with heater on full until there is no more air in the system. How do I know when there is no more air in the system?
Should I use OEM toyota coolant with water wetter? Or is there a "better" coolant I can use?
Any other imporant details that I should know about? Thanks.
Old Jan 22, 2004 | 06:26 AM
Carpe Diem's Avatar
Carpe Diem
See these thread:
https://www.clublexus.com/forums/sho...hreadid=105214
https://www.clublexus.com/forums/sho...hreadid=107045
George
khailon
Mar 2, 2011 08:14 PM
johnnybmw1
Sep 20, 2010 02:14 PM
Sleepr
GS - 1st Gen (1993-1997)
Oct 6, 2009 07:43 AM
swat1727
May 7, 2008 10:26 AM
actuary
Jul 21, 2005 04:22 AM
