Code 21 Solar Sensor. A/C wont work!
Old Sep 23, 2013 | 12:25 AM
Lokz's Avatar
Lokz
Default Code 21 Solar Sensor. A/C wont work!
I really need help in the wiring diagram of the A/C. My blower works, heat works, even when i press the a/c switch the green light turns on for the A/C, The compressor wont kick in at all. Its a 1JZ Soarer swap SC300 with Dr.Tweaks harness. I dont know where to start from or how to figure this out. Code just says Solar sensor is open. I did use the research box which tells me i will get that code if the car is in shade. But it throws this code in the light too.
HELP! I want to make the A/C work!! although the winter is coming, i just want to prepare for the warm weather already.
Thanks in advance!
Cheers
Old Sep 23, 2013 | 05:18 AM
97-SC300's Avatar
97-SC300
i have the same thing... any help would be great
Old Sep 23, 2013 | 07:21 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I am assuming you too are using the stock ECU? If you have the AEM I can help. I have read many threads on this and to fix the problem you two are having is to run a relay. Let me see if I can find the thread on this. If you have the AEM, use A17 and A27 for the AC to kick on and off. That's how I have mine ran. Works great, no issues, except for the idling from time to time.
Old Sep 23, 2013 | 04:04 PM
Lokz's Avatar
Lokz
Running stock ECU. A17 AND A 27? are those the pin outs on AEM? I'm wondering if anyone else ran into this problem before and figured it out on stock soarer ECU
Old Sep 23, 2013 | 08:19 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Yeah those are the pinouts for the AEM. Did you find the thread on the relay that several have had to use?. Try even SF(supraforums).
Old Sep 25, 2013 | 05:07 AM
Lokz's Avatar
Lokz
Not yet, all the threads i have come across are leading me no where. If you are able to find a link please PM me i would greatly appreciate it, meanwhile i will look for it too. I can wire up the relay, but i need to know which pins run the compressor from ECU.
Old Sep 25, 2013 | 06:33 AM
99SC42's Avatar
99SC42
Thanks in advance!
Cheers
I have a 1jz in my garage with a working a/c system, Give me sometime to pull the harness out and chase the a/c wiring down and i will tell you what to do to get it to work, i promise.
You are using a supra ECU? Or JDM ecu?
Old Jan 4, 2014 | 04:24 PM
97-SC300's Avatar
97-SC300
I still can't figure it out. Had dr.tweak make the harness originally for aristo ecu. I never ran it and put in a supra jdm 6 speed ecu. Tweak has a relay wired into the harness for the ac. The compressor will not kick on. Tweak told me to remove the relay by cutting the two wires coming from the ecu and cap them off and the other two going to the engine connect together. I did hat and still nothing. Any help oumar? Light comes on green when I push the ac bottom on climate but compressor will not come on.
Old Jan 4, 2014 | 05:20 PM
99SC42's Avatar
99SC42
I'll help you out give me till tomorrow morning please.
Old Jan 4, 2014 | 05:36 PM
97-SC300's Avatar
97-SC300
Thanks. I'll keep checking this thread
KG01
Jan 4, 2020 12:50 PM
Ravencrave
Nov 25, 2013 08:11 AM
horent135
Jun 25, 2010 11:12 AM
hipendicul
Jun 23, 2008 10:51 PM
snshn1314
Jan 5, 2007 09:15 AM
