Sc400 Acceleration Problem
Old 12-26-10, 07:58 PM
KrazeMatik
KrazeMatik's Avatar
sound like transmission solenoid
Old 12-26-10, 08:00 PM
SW2UZ
SW2UZ's Avatar
Originally Posted by CoryJNason
Also, when I reset the codes, when the check engine light comes back on, so does the traction controll off light. Why is that?
MAF still unplugged?
Old 12-26-10, 09:04 PM
sc3tech
sc3tech's Avatar
sounds like your trans is slipping or a torque converter issue.
Old 12-27-10, 10:01 AM
CoryJNason
CoryJNason's Avatar
It shifts a little hard in second and third but no slipping or anything. MAF is plugged in.
Old 12-29-10, 08:24 AM
CoryJNason
CoryJNason's Avatar
Replaced the maf today. Did nothing!
Old 12-29-10, 01:29 PM
LunaVyohr
LunaVyohr's Avatar
I've said this I think three times now, but stop wasting so much money on **** that's probably not gonna help and just get it diagnosed. In the end, it probably will save you some money.
Old 01-11-11, 06:34 PM
CoryJNason
CoryJNason's Avatar
fixed it! Check the first post!
Old 01-13-11, 04:01 PM
Jysc400
Jysc400's Avatar
What was your problem with the acceleration? Pls Lmk. I have a similar problem as well. Thanks in adance.
Old 01-14-11, 12:25 AM
avilajose
avilajose's Avatar
I had the same problem. I had a different code i got a 13 code tho. both my CEL and TRAC light would stay on and it was a camshaft position sensor. Test them with a ohm meter. if you get a OL reading that means the sensor is bad.
Old 01-14-11, 11:06 AM
Joey-E
Joey-E's Avatar
I have a 92 sc400. It has 141k. It has a bad acceleration problem. I dont know what it is. It idles fine and then when I go to drive it, it has no real power. It will gradually accelerate and go through the gears. I have replaced the plugs, about to do the wire. Could it be the fuel pump? HELP!?!?!? This is my only car and I need to get it fixed NOW!! PLEASE HELP
UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE-UPDATE
Replaced a coil on the right side of the engine(when looking at the engine) and it runs GREAT NOW! I dont have any shifting problems or anything anymore! Going to reset the codes and see if it still spits out a 25. If it does its probably just an o2 sensor but nothing big. Thanks for all the inputs!
Originally Posted by Joey-E
Check your Ignition Coils
Old 02-26-11, 11:09 AM
micgiordan
micgiordan's Avatar
Default 92 SC400 - not running on all 8
Car ran perfect, went to store - block later fell on face - feels like running on 3 or 4 cyclinders. Starts, idles ruff. Replaced both coils & fuel filter - no change. 1 coil drivers side was bad. Dont know where to go from here. Car has 177k miles.
Old 05-08-12, 02:15 PM
Bott63
Bott63's Avatar
Any update?
Old 05-09-12, 02:45 PM
Bott63
Bott63's Avatar
Can anyone please share the exact location of BOTH coils? I'm having similar issues, and will be replacing the original 19 year old coils soon...
Christian
12-10-12 03:02 PM
marcojdm
11-27-12 04:39 PM
Revhead95
05-22-12 05:56 AM
Onitlex96
06-14-11 10:09 PM
randomjoe
06-29-10 09:36 PM
Quick Reply: Sc400 Acceleration Problem
