diagnostic question
Old Aug 27, 2009 | 10:18 AM
soarer13oy's Avatar
soarer13oy
Default diagnostic question
i tried checking for codes but all it does is continuously blinks fast. What does this mean? I did have code 71 but after i rerouted the vacuum lines and pulled the negative cable off for a good five minutes, i just got this countinous blinking.
Old Aug 28, 2009 | 08:04 PM
1siksc's Avatar
1siksc
71 is an egr malfunction code, The flashing is cause of the ECU reset and the scanner probably.
Old Aug 28, 2009 | 09:49 PM
soarer13oy's Avatar
soarer13oy
Well check engine lights hasnt come back. I hope it stays that way.
Old Aug 28, 2009 | 09:59 PM
bangdangvn's Avatar
bangdangvn
or you can put a resistor into the temp. sensor
Old Aug 28, 2009 | 11:50 PM
soarer13oy's Avatar
soarer13oy
Would this play any effect with smog because im pretty sure im going to have to smog my car at the end of the year. Plus i live in cali. I just want to pass it without having to repair anything, because im planning to swap it in the spring.
Old Aug 29, 2009 | 05:55 AM
1siksc's Avatar
1siksc
As long as the CEL doesn't come back on you should be fine. The EGR really only opens at Idle.
Old Aug 29, 2009 | 10:47 AM
ihiryu's Avatar
ihiryu
the constant blinking is to let you know that you don't have a code. Or it can also mean "code 0"
Old Aug 29, 2009 | 03:26 PM
soarer13oy's Avatar
soarer13oy
ok kool. usually when i reset my ecu it cel comes back a day after, but it hasnt come back yet. Thanks by the way, exactly what i was looking for.
Old Aug 29, 2009 | 04:08 PM
1siksc's Avatar
1siksc
Not a Problem, happy to be here to help!
Old Aug 29, 2009 | 04:57 PM
HellFish's Avatar
HellFish
not really it opens during cruise. if it opened up only during idle then the idle would stumble.
and to the op the light is blinkin because the ecu has been reset and there are no codes stored. you should be able to pass smog, since there is no OBD II functional check for your car so id say reset the light before the test. and hope it doesnt come on during the test.
Slickcam
GS - 1st Gen (1993-1997)
Feb 29, 2016 05:34 AM
dsouth
Jul 4, 2012 09:39 AM
imDementeD
Mar 8, 2011 01:03 PM
CallmeQ
Sep 26, 2009 12:19 PM
StiCk3
Apr 26, 2008 05:40 AM
