timing belt replacement on SC300
Old Jul 17, 2005 | 01:24 PM
Inabj2's Avatar
Inabj2
Originally Posted by TMaxxTim
Yes, the 2JZ-GE Non-VVTI and 1UZFE are NON-Interference engines. Nomatter how badly you f'up the timing, it won't bend valves....EVER!
I don't know what kind of engine you're talking about here gserep1, but the 2JZ-GE in the SC300 (Non-VVTI) are non-interference.
Thats what I thought! Even the more reason for me to do this!
To bad I wont be able to start till the weekend of 31st or so due to scheduling reasons, lately i been driving the car very sparingly (work and back only, i try to keep my weekend outings by riding in my roomates wrx..) So I hope belt lasts me till then. Today Im going to finish what I had planned for this car and replace my radiator and experiment running with water and water wetter in sunny az, which worked wonders when my 240sx was running (better response it removed all overheating issues which I dont have with the sc300 etc etc, only drawback is that it took forever to warm up.)
Old Jul 30, 2005 | 05:35 PM
Inabj2's Avatar
Inabj2
Is there a specific sized pulley I need for the job? Instructions I obtained give me a part number for the pulley extractor but that looks to be a lexus specific tool I wonder to what thad translate too for a general pulley extractor?
Old Jul 31, 2005 | 09:26 AM
TMaxxTim's Avatar
TMaxxTim
go to autozone and ask for a crackshaft puller. its 2 screws that go into the crankshaft pully and one big **** that you screw into the middle and as it goes it it pulls the pulley out. its also known as a harmonic balancer puller.
Old Jul 31, 2005 | 03:15 PM
Inabj2's Avatar
Inabj2
were doing the timing belt as we speak in the instructions my brother sent me vie email..
It is interesting to note that this engine for 1992-1997 SC300 is classified as an INTERFERENCE Engine!!!!
Check for engine Damage:
Caution: This engine has been identified as an INTERFERENCE engine in which the possibility of valve to piston damage in the event of timing belt failure is MOST LIKELY to occur.
A compression check of all cylinders should be made before removing cylinder head.
Wow I guess we were wrong about that one! Ill start a new thread about it later...
Old Aug 2, 2005 | 04:54 AM
dejacky's Avatar
dejacky
I hope it's not classified like that via the Service Manual. The official Lexus service manual also says our 2JZ-GE engines have oil pan baffles, but DaveH confirmed they don't!
Old Aug 2, 2005 | 05:09 AM
Project300's Avatar
Project300
That would explain the continual "debate" about non-interference vs. interference. I know my 93 is non-interference and I didn't read it in a manual to find out. Any manual that states valve damage is "likely to ocurr" when the belt breaks is just bad information. Either it WILL or WILL NOT depending on whice 2JZ you have.
If you have a VVTi it is possible, non-VVTi impossible.
nefariousd
May 10, 2022 01:11 PM
greenpea
Mar 29, 2009 11:14 AM
shajbot
Maintenance
Jan 20, 2009 01:47 PM
OlschoolGs
Apr 18, 2005 09:18 PM
Seminole GS300
GS - 1st Gen (1993-1997)
May 21, 2003 04:27 PM
