Timing belt kit for 95 sc300?
Old Apr 21, 2009 | 12:27 PM
nefariousd's Avatar
nefariousd
Default Timing belt kit for 95 sc300?
I have a 1995 sc300 with about 140k. I just got the car and it needs a tune up real bad. I just changed the spark plugs, wires, distributor, and thermostat. what else would i need to change. Where can i get a good timing belt kit and not that ebay stuff. I was thinking of just buying thing separately like a Gates t215rb timing belt and Timing Belt Tensioner Bearing but after that im lost as to what to get. Any suggestions?? Also i have searched and searched on this forum with no success.
Old Apr 21, 2009 | 03:01 PM
UZZ30-SC4's Avatar
UZZ30-SC4
Dont do yourself the backwards work of getting aftermarket timing parts...go oem and do it right the first time.
Old Apr 21, 2009 | 09:24 PM
dwebb99's Avatar
dwebb99
certain parts I like to go with oem.....timing/water pump stuff...OEM always! makes me sleep better.
Old May 4, 2022 | 08:18 AM
glbg's Avatar
glbg
Heel & Toe
I have a 1998 SC300 , I will need to perform a timing belt maintenance. I am planning to do it myself. I saw the the kit below on ebay. Are the non -Toyota parts good? any other recommendation?TIMING BELT-MITSOBOSHI Part#TB215M
IDLER-KOYO Part#13505-46041
HYDRAULIC TENSIONER-TOYOTA Part#13540-46030
DRIVE BELT - BANDO/MISTSU Part#6PK-1930-40
FRONT CAM SEALS -TOYOTA 90311-40020
FRONT CRANK SEAL – TOYOTA 90311-46001
WATER PUMP -AISIN/ASCO Part#16100-49837-83
ORING & GASKET -AISIN/ASCO
THERMOSTAT – TOYOTA 90916-03093
THERMOSTAT GASKET – TOYOTA Part#16325-62010
OIL FILTER - TOYOTA Part# 90915-YZZD1
OIL PLUG GASKET TOYOTA Part# 90430-12031
Thanks in advance.
Old May 10, 2022 | 01:11 PM
GAsc300's Avatar
GAsc300
Default Lots of options rockauto or parts geek
Because most of these parts are made by other vendors it’s easy to get the oem makers used by Toyota/Lexus or high quality alternatives from rockauto.com or partsgeek.com to name 2 I use most often. Their “kit” versions for water pump and or timing beltbinclude most of what you need in one list (usually mix of different brands) or get whatever version you want of each part separately. I just replaced my 93 sc300 serpentine belt and water pump and timing belt and related wear and tear parts using both these places. Did fan clutch too and radiator and hoses too but I’d been having overheating issues from every cause possible.
Definitely get a water pump that includes the housing with the pump as pump only likely won’t fit to your original water pump housing. A member warned about this 15 years ago in a post and I had to learn hard way a month ago.
If you get new housing you should replace 3 o rings available from Toyota that fit on water bypass elbow behind water pump housing. I think parts geek includes the Toyota part numbers with the water pumps they sell but u gotta buy em from Toyota or Lexus yourself. Can replace camshaft seals too but I didn’t.
Stemmer
RX - 1st Gen (1999-2003)
Jan 12, 2022 06:27 PM
spitfire7
Jan 27, 2015 09:19 AM
es30000000
Jun 7, 2012 05:19 PM
Harpo
Nov 28, 2011 06:12 PM
swat1727
Dec 11, 2008 12:44 PM
