Just drove through car wash
First I turned off the collision mitigation system and warning system and now that I know how to put the car into neutral ha ha
anyway water under the door when you open the door the bottom of all of the doors has water and on the sill I don’t remember having that problem with other cars but maybe.
I KNOW THE FEELING. I hope this helps... The shifter is electronic and has a slight delay. It is not a cable and when I select DRIVE it doesn't go into DRIVE (or REVERSE or NEUTRAL) for 1.5 or so seconds. If I remember that then I can shift all day long without any issues. This is not a cable shifter with gears which I can feel right away, it is more of a computer input and many things need to be checked before the system does as it is programmed.
The beeping and lights will still go off as if you’re about to hit the different things around you but the car won’t stop by itself if you turn off those systems.
I think they're referring to car washes where the car is dragged along a track... they're much more rare in Ontario/Canada ... we just drive in, stop and the washing mechanism goes around the car..i think these are more rare in US
No need to turn anything off once in neutral with the exception of the auto rain wipers. Going through a car wash causes all sorts of lights and bells to go off, as each sensor gets blocked and the car is trying to figure out what’s going on. Once through the brushes and the car is being dried everything settles down.
I have had it apply the brakes when I am getting too close to something.
It wont do this in neutral. No need to turn anything off. I have had a 2018,2019,2020, 2021, and now a 2022 and none of them had any problems going through a car was in neutral.
akfd
GX - 2nd Gen (2010-2023)
Jun 15, 2010 06:36 PM
