NX - 2nd Gen (2022-current)
AC outlet in 450h+
Old Sep 6, 2022 | 07:02 AM
chiguy's Avatar
chiguy
Default AC outlet in 450h+
So I was a bit bummed that Lexus didn't include the 1500 watt AC outlet in the NX like you can get in the RAV4 Prime. I'd like to get something that can handle a bit more watts than just the small inverters that plug into a lighter plug, which top out around 150 watts. I'd like something around 400 watts that can power a high end laptop or such. Given the 12v battery location in the 450h+, connecting such an inverter to it would be much easier than in most cars, where the battery is under the hood.
However, given how the low voltage and high voltage stuff is all tied together, I'm reluctant to try such a thing without knowing in great detail what's acceptable and what's not. Anyone know a safe, warranty compliant way to add an AC outlet with decent wattage handling to the 450h+?
Old Sep 6, 2022 | 08:17 AM
shiftD7's Avatar
shiftD7
I have seen some trims of the '22 NX have a 120V Plug (two prong household). But I'm not certain which trims/models/packages would contain the 120V Plug.
Old Sep 6, 2022 | 08:23 AM
Ihave1cat's Avatar
Ihave1cat
I've seen that only the 350 - non hybrid has it. I'm not sure why, but it seems that it's the only model of the 2022 NX that does.
Old Sep 8, 2022 | 01:23 AM
CdO's Avatar
CdO
Default I was also disappointed.
Originally Posted by chiguy
...given how the low voltage and high voltage stuff is all tied together, I'm reluctant to try such a thing without knowing in great detail what's acceptable and what's not...
It's pretty simple in principle. The high voltage battery feeds ~355V power to the DC to DC converter which powers the ~12V system. I am pretty sure the DC/DC converter is rated at 150 amps (150A x 12V = 1800W). Pretty much everything except the heat pump and other electric motors run on the 12V system like any traditional car.
Note: Since the 12V battery doesn't start the ICE it doesn't normally do much, it's only really used in accessory mode (and Neutral?). I wonder how robust (what gauge) the cabling to it is since it doesn't have to provide the ~500 cranking amps most vehicles would. Assuming the cables can meet your inverter demand I don't foresee any issues (if not, you might consider connecting directly to the converter... where the battery is ultimately connected). Anyone know how the RAV4P inverter is connected? Just make sure you're not charging, everything is off, disconnect the 12V negative terminal, and after 10 minutes there will be no danger of high voltage (the battery disconnects internally when off and/or without 12V power).
(I'm supposed to get mine soon; so, can't help further.)
Old Sep 28, 2023 | 03:56 PM
Downtownalways's Avatar
Downtownalways
10th Gear
Default Breaker keeps tripping
Hello. I have an NX 450h+. When I charge using a household 3 prong plug, the charging appears to pull too much current and the breaker pops, typically within a hour of charging but sometimes less and sometimes a bit more. Is there a charger that pulls less current? An adapter? A setting in the car?
thank you for any comments
Old Sep 28, 2023 | 05:46 PM
nx450plus's Avatar
nx450plus
manual says
Select on the center display.
2 Select [Vehicle customize].
3 Select [Charging].
4 Select [Charging current].
5 Select [16A]*6 or [8A] on the charging current screen, and then press [OK
Old Sep 28, 2023 | 07:59 PM
Downtownalways
10th Gear
Thank you!! I will try that.
Old Sep 29, 2023 | 11:19 AM
Downtownalways
10th Gear
Originally Posted by nx450plus
manual says
this info worked perfectly. Thank you!!
jhruzek
May 5, 2021 05:06 PM
joindy
GX - 2nd Gen (2010-2023)
43
Sep 2, 2019 11:21 AM
pmnuon79
Oct 22, 2014 12:05 PM
lexigirl06
Jun 30, 2008 02:32 PM
