My husband has a 2021 or 22 NX and has had this problem from day 1. He HATES his car because of this and has tried everything. He says the car is awesome but because of this echo he will never buy another Lexus. Makes me sad as we've had multiple Lexus over the last 20 years. If you have found a solution for iPhones and the echo, please let me know. The dealership in Houston has no clue, but clearly it's an issue.
Try
iPhone Instructions
Go to your settings app
Tap at top to open search bar – enter “noise”
Scroll to “phone noise cancellation”
If it is off turn it on
Ensure phone volume is near or at the highest setting
Ensure the Bluetooth audio is set to around 28-32. Test and set during active phone call
Test volume settings with phone calls to each other while phone user is in vehicle and car is on, to see if this helps
Thanks, but the wife's phone doesn't have those settings.
Try for S7 Open the "Settings" app on your Galaxy S7. Scroll down and tap on "Sounds and vibration." Look for "Sound quality and effects" or a similar option. Within this menu, you should find the "Noise reduction" setting.
I'll do that maybe tomorrow, thanks. It's an S10e, by the way.
I'm still not finding it. Assuming I do, are we wanting to turn noise reduction on or off?
I was wondering if anyone has found a solution to the cell phone echo issue when connected via bluetooth. I have no problems when connected via android auto, but when it is connected blue tooth the person on the other ends gets a very obnoxious echo. Thanks.
