NX - 2nd Gen (2022-current)
Key Fob Battery
Old Jul 20, 2025 | 08:14 AM
Karenodesigner's Avatar
Karenodesigner
10th Gear
Default Key Fob Battery
Do you replace your own or let the dealer service dept. do it? Will they do it for free if I buy the battery thro' them?
Old Jul 20, 2025 | 08:26 AM
websurfer's Avatar
websurfer
Easy enough to diy that. Tons of videos on youtube if you wondering how to change the battery.
Old Jul 20, 2025 | 09:28 AM
ChattanoogaPhil's Avatar
ChattanoogaPhil
Wife went to BatteriesPlus. They have a one-time fee for key fob battery replacement or lifetime fee.
Wife chose lifetime.
Old Jul 20, 2025 | 10:07 AM
ThisIsMyName's Avatar
ThisIsMyName
If you replace yourself, when you insert the metal key into the plastic slot, make sure you push in kind of hard as you rotate. If you don't push in, you might strip the plastic.
You can get 5 batteries for $5.20 here. You can store them new for 5-10 years.
Amazon Amazon
There's a "low battery usage" mode. Useful if you're not driving the car everyday. Press and hold "lock", then press "unlock" once. You see a light blink 4 times.
Old Jul 20, 2025 | 12:46 PM
midcow3's Avatar
midcow3
Lightbulb Key Fob uses CR-2032 Lithium battery
It uses a CR2032 lithium battery and replacement is very simple. A flat blade screw driver pops open the key fob, replace battery pop back together. At Amazon they are $0,60 to $1,24 each.
Very curious, @ChattanoogaPhil , how long do you have to wait and where do you go to get the "Expert Installation". You are going to have to do a whole lot of battery replacements to get you money's worth.
YMMV,
MidCow3
Old Jul 20, 2025 | 11:30 PM
hintonwood's Avatar
hintonwood
YMMV,
MidCow3
The UK Keyfob on my 2022 NX 350h has no slot to insert a blade. Rather, one half slides off to reveal the battery. No tool required.
Old Jul 21, 2025 | 05:17 AM
ChattanoogaPhil
BatteriesPlus is in the Hamilton Place shopping mall area on Gunbarrel. It's not an inconvenience as the wife is regularly in the area. I doubt there's much if any wait. The previous owner told her B+ replaced the key fob batteries every couple years. Wife is happy for $30. Worth every penny...
Old Jul 21, 2025 | 10:17 AM
midcow3's Avatar
midcow3
@ChattanoogaPhil Great solution in your case. Happy wife , Happy life.
YMMV,
MidCow3
Old Jul 21, 2025 | 01:45 PM
jgrnt1's Avatar
jgrnt1
I used to change mine myself. Now I have a calendar reminder to change them each January 1st. I go to BatteriesPlus.
Last 5K mile service, the dealership offered to replace the battery. I had just had it done at BatteriesPlus, so I said no. They auto-piloted and did it anyway (it was only $2.50 for the battery, so not a big deal). Since they changed it, I was having all sorts of "key not detected" problems when starting. Sometimes I was also unable to lock or unlock the doors with the fob. I went to BatteriesPlus and put in a new battery again last week. Now it all works again.
Old Jul 21, 2025 | 02:19 PM
ChattanoogaPhil
Last 5K mile service, the dealership offered to replace the battery. I had just had it done at BatteriesPlus, so I said no. They auto-piloted and did it anyway (it was only $2.50 for the battery, so not a big deal).Since they changed it, I was having all sorts of "key not detected" problems when starting. Sometimes I was also unable to lock or unlock the doors with the fob. I went to BatteriesPlus and put in a new battery again last week. Now it all works again.
You mean I could have saved $30 by changing the battery myself, then have the pleasure of the wife giving me the look and asking why the doors don't lock or unlock? What a deal...
Old Jul 21, 2025 | 04:18 PM
TheCDN's Avatar
TheCDN
If you can use a key to unlock the entry door to your home you should be able to replace the battery in your key fob. It's that easy. One very important rule, never buy cheap dollar store batteries, it's not worth it. Always check the expiration date on package of battery make sure its several years out, as batteries can go stale sitting on the shelf in a store.
The video is less than 2 minutes long, so it's not that hard and no tools needed with Lexus fob either!
Here's how to replace Card Key battery too.
Be careful to use correct battery part number too! It's a CR2032. There is a CR 2025 (wrong one!) coin style battery which may work in the fob but it's not as powerful and dies quickly.
" What’s the difference between CR2032 and CR2025 batteries?
The obvious difference between the two battery types would be thickness. The CR2032 is 3.2mm thick while the CR2025 is 2.5mm thick. Because the CR2032 is 0.7mm thicker than the CR2025, it has a higher capacity (mAh) to deliver current to the load. A standard CR2032 can nominally deliver 225mAh while the average CR2025 can nominally only deliver 160mAh. Due to the smaller capacity, the thinner battery may not last as long and may need to be replaced sooner."
Lunfengzhe
14
Jul 21, 2025 04:16 PM
ionian
ES - 7th Gen (2019-2025)
17
Sep 30, 2022 12:28 PM
Albo
Mar 25, 2020 09:26 AM
seenitall
Aug 3, 2016 12:49 PM
dat dude
RX - 3rd Gen (2010-2015)
Apr 28, 2014 06:44 AM
