NX - 2nd Gen (2022-current)
Tire suggestion
Old Sep 13, 2024 | 11:24 AM
tiLLIKS's Avatar
tiLLIKS
Default Tire suggestion
Hey all,
So I recently had a flat and plugged it, but I’m going to use this as an excuse to get regular tires instead of the run flats. Can anyone suggest good tires?
also, what did you do in terms of having a spare? There isn’t a spot for a spare tire
Old Sep 13, 2024 | 11:51 AM
tundotcom's Avatar
tundotcom
Where in NY are you?
I'm in NYC and I plan on switching to Pirelli Scorpion AS Plus 3 when my runflats wear out. If you live more upstate with higher snowfall, I would probably go with the Michelin Cross Climate 2 if you don't want to run a dedicated winter tire.
As for the spare, a lot of us use theis Modern Spare kit.
https://modernspare.com/product/2025...e-kit-options/
If you have a hybrid, you are out of luck in terms of storage under the trunk floor. If you have one of the gas models, you can remove the storage bins and place the spare tire there.
Old Sep 13, 2024 | 06:02 PM
websurfer's Avatar
websurfer
I'm thinking about tires also but my vehicle isn't ready for it yet.
I'm thinking Michelin Cross Climate 2 or YokohamaGeolandar X-CV.
Another thread has been discussing this a lot.
https://www.clublexus.com/forums/nx-...run-flats.html
Old Sep 13, 2024 | 07:07 PM
tiLLIKS's Avatar
tiLLIKS
I'm in NYC and I plan on switching to Pirello Scorpion AS Plus 3 when my runflats wear out. If you live more upstate with higher snowfall, I would probably go with the Michelin Cross Climate 2 if you don't want to run a dedicated winter tire.
hey, thanks for the reply. I live on long island but I commute to the Bronx everyday.
and yep, I have a hybrid
Old Sep 14, 2024 | 06:41 AM
tiLLIKS's Avatar
tiLLIKS
they mentioned that the CC2 lowers the MPG by 2-3. Would that be worth it?
Old Sep 14, 2024 | 08:10 AM
tundotcom's Avatar
tundotcom
No IMO. We don't get enough snowfall these days to warrant it. Our roads are usually cleared out after any snowfall anyway.
Old Sep 14, 2024 | 08:23 AM
websurfer's Avatar
websurfer
That's the part that I have been thinking if the ride is harsher and I'm not sure about lowering MPG. I saw a few other videos online from youtubers that have the CC2 and they claimed MPG is around the same but the ride is noisier.
The tires are harder so it will last longer and is pretty good over snow (we don't have snow in CA). I'm undecided yet and also I hope the RFT last a bit. Some people mentioned it's lasts to around 25K miles with 5K rotation.
I was also looking at Yokohama and that's a softer tire so it probably won't make it to the mileage. Both are around the same price.
I have the 20" wheel but there are more selection for the 18" wheel.
https://www.americastire.com/fitment...rt=recommended
Old Sep 14, 2024 | 08:32 AM
tiLLIKS's Avatar
tiLLIKS
I wonder if having less mpg is worth the switch? On the website on discount tires, it says it gives higher mpg.. is this 100% confirmed?
Old Sep 14, 2024 | 08:33 AM
tiLLIKS's Avatar
tiLLIKS
Should I just go back to the factory run flats or is there a better one?
Old Sep 14, 2024 | 09:16 AM
websurfer's Avatar
websurfer
The rating on the OEM RFT are not that great in the rain per reviews. I will find out this winter to know more.
https://www.tirerack.com/tires/tires...D&autoModClar=
Old Sep 14, 2024 | 03:36 PM
websurfer's Avatar
websurfer
Here's what I found the most helpful video on CC2
Old Sep 14, 2024 | 04:36 PM
tiLLIKS's Avatar
tiLLIKS
https://www.youtube.com/watch?v=PT2odY3C6Og&t=29s
thank you thank you. I kinda skimmed through to certain sections like and it seems like the choice, but my only concern is the drop in mpg
Old Sep 14, 2024 | 05:43 PM
jatwell's Avatar
jatwell
I’ve had both the Pirelli Scorpion AS Plus 3 and Cross Climate 2. The CC2 is (surprisingly) quieter, but does lower my MPG by about 1 MPG. Both are excellent, but I prefer the CC2.
Old Sep 14, 2024 | 06:50 PM
midcow3's Avatar
midcow3
Lightbulb
Not everyone sees a drop in mileage, Based on pure physical specs (exact same diameter) and the CC2 weighing less IMHO the reported mile mileage drop to me is not convincing. I am getting CC2 when I need to replace, but since I don't drive the NX very much ( actually I don't drive that much period) it may be awhile.
YMMV,
Midcow3
Old Sep 15, 2024 | 07:24 AM
tundotcom's Avatar
tundotcom
What were your thoughts on ride comfort and handling between the two?
