NX - 2nd Gen (2022-current)
Modern Spare Question
Old Mar 10, 2024 | 01:08 PM
user 082089340294's Avatar
user 082089340294
Guest
Default Modern Spare Question
Hoping I never need to use the spare, but I'm wondering what PSI people keep in the Modern Spare? The same as the regular tires or is there something different about how the spare needs inflation? Thanks in advance.
Old Mar 10, 2024 | 02:32 PM
midcow3's Avatar
midcow3
Lightbulb 60 psi
Here you go @romer , I'll look it up for yah
Kumho (131) Original Equipment T155/90R18 113M
The Kumho (131) Original Equipment T155/90R18 113M is a compact spare tire that should be inflated to 60 psi and not driven faster than 50 mph. It has a continuous center rib that provides controllability and maneuvering.
YMMV,
MidCow3
Old Mar 10, 2024 | 02:38 PM
user 082089340294
Guest
Thanks MidCow3--much appreciated. I asked Modern Spare a while back but got a non-specific answer. Again--hoping it remains in brand new condition forever!
Old Mar 10, 2024 | 08:56 PM
oreon333's Avatar
oreon333
The real question is do you have a regular tire as a spare, or a real compact spare tire, if it is real spare it would says right on the tire to inflate to 60 psi or whatever, but if you keep a regular tire as a spare do not think I would keep it at 60 psi
Old Mar 10, 2024 | 09:10 PM
user 082089340294
Guest
Often tires will show the maximum PSI. The actual PSI is determined by the car it's on. I have the Modern Spare and it says 60 PSI which I wasn't sure about. As I said--I contacted them but the response was not definitive for some reason. MidCow3 confirmed the 60 PSI answer so there you have it. Just don't want to have to use it--fingers crossed.
Old Mar 10, 2024 | 09:16 PM
midcow3's Avatar
midcow3
Exclamation
Asked and answered, Modern Spare is a compact spare. Obviously not full size if you look at the tire specifications that were provided.
Peace YMMV,
MidCow3
Old Mar 11, 2024 | 11:01 AM
TheCDN's Avatar
TheCDN
For temporary spare tires always read the sidewall to make sure what maximum pressure it will take and never go any higher. As they always will typically be higher pressure than a regular full size spare it's always a good idea to check this pressure at least once a year as they tend to slowly loose pressure over time and there's no TPMS in them to tell you they're low. And like old Murphy will tell you: when you need it most is when it'll let you down (ok that's a little different than what Murphy says ' .
okc329
Jul 15, 2010 11:02 PM
Mesca
Wheels, Tires & Brakes Forum
Nov 27, 2008 06:49 PM
sonikbo0m
Mar 25, 2007 10:10 AM
twister
Dec 6, 2006 11:02 AM
