Replace dashboard speakers
They are fine. I use these from Audiofrog.GS25 2.5" (65mm) Premium Grade Full Range Automotive Loudspeaker - Audiofrog
Do you think the GS25’s are likely better even though they are only 2.5” instead of 3.5” like the JL’s?
I have not heard the ML system, but, it would be interesting to compare the beefed up dash system.
Of course, system sound is very subjective
No disrespect to existing ML owners.....
Hmmm, I’m just trying to buy whichever is better for full range corner dash speakers (likely not replacing door speakers or adding an amp so I think that means I shouldn’t worry about tweeter-only for that location). Planning to eventually add either a AIO powered sub or mini amp for stock sub to help out the low end as well.
Car Speakers by Category - Car Audio - JL Audio
Audiofrog makes a variety of presumably quality speakers and has chosen GS25 as the single 2.5" wideband for their car audio division. It has to be good.
JL audio makes 7 grades, C1 to C7. Objectively C2 is toward the bottom of that continuum.
[QUOTE=Electric65;11777604]Köszönjük a megerősítést! Továbbra is a JL Audio C2-350x a legjobban ajánlott hangszóró a műszerfal sarkaihoz, ha erős erősítőt használunk?[/QUOTE
#Atomiclexus wrote several times that there is a (reasonable) financial limit to which an update can go. I think C2 is the limit.
First time poster here. Today I installed the JL Audio C2-350x with the Metra 72-8109 in the left and right side of the dashboard. Everything went smoothly, the only advice I have is when putting the right side grill back in, wedge something between the A-pillar and the grill as it is going to scuff up the fabric on your A-Pillar if you do not. The mounting holes were a few millimeters shy of perfect, but when you install them at an angle they straighten out when tightened. My initial impressions aren't favorable, though. I'm sure anything is an improvement over the stock speakers, but the center speaker seems to overpower everything. I was excited about the C2-350X because they are 83db@1w but have a bit of buyer's remorse as the improvement wasn't tremendous. In some videos I see the speaker cone vibrating aggressively but on the C2's it barely moves. Using the eq settings has made me a bit happier, but I'm wondering what all of your thoughts are on why this might be. Would replacing the center speaker fix things or make it worse? Are the C2-350x particularly power hungry and the stock pioneer amp isn't suited for it? Thank you in advance.
Last edited by audign; Oct 5, 2024 at 04:45 PM. Reason: added a tip for right side grill
83db is quite poor even for a 3.5" speaker which tend to have lower efficiency. This one is 88
https://www.crutchfield.ca/p_20651KS....html?tp=73208
But specs are not sound so don't get too hung up on them. Give the speakers at least a few hours to break in but it's possible the JL's won't play loud enough compared to the center channel. I personally think a center channel for music shouldn't exist but that's another discussion.
YMMV,
MidCow3
First time poster here. Today I installed the JL Audio C2-350x with the Metra 72-8109 in the left and right side of the dashboard. Everything went smoothly, the only advice I have is when putting the right side grill back in, wedge something between the A-pillar and the grill as it is going to scuff up the fabric on your A-Pillar if you do not. The mounting holes were a few millimeters shy of perfect, but when you install them at an angle they straighten out when tightened. My initial impressions aren't favorable, though. I'm sure anything is an improvement over the stock speakers, but the center speaker seems to overpower everything. I was excited about the C2-350X because they are 83db@1w but have a bit of buyer's reemorse as the improvement wasn't tremendous. In some videos I see the speaker cone vibrating aggressively but on the C2's it barely moves. Using the eq settings has made me a bit happier, but I'm wondering what all of your thoughts are on why this might be. Would replacing the center speaker fix things or make it worse? Are the C2-350x particularly power hungry and the stock pioneer amp isn't suited for it? Thank you in advance.
I replaced the 2 corner dash with Hertz Cento's and didn't get the quality I was expecting with mp3 audio files.....I already had surround turned off so my center channel wasn't too loud. I felt there was some sound balance issues but I did go in and adjust the hesd unit EQ settings and lowered mid and treble. That seemed to help.
With over 300 posts its really a pain to read thru and sift the " wheat from the chaff."
When I decided to tackle changing the 3 front speakers and adding a small amp (I've got the NX350h) I did go thru every post, noted which were helpful to the conversion and followed the guidance. Recall that AtomicLexus said right at the get go, this is a bang for the buck endeavor and short of replacing the entire audio system these mods are a pretty healthy improvement . And, considering we are using a vehicle in a noisy environment. The modifications hit my sweetspot. Others may be more demanding .
You mentioned mp3 files,....they have their resolution limits, but the higher bitrate mp3's can sound pretty darned good in a vehicle if a well recorded song from a savy audio engineer put the information there to begin with......
The "Subwoofer" thread, started by AtomicLexus and added to by a few others who are "hardcore" great stereo guys have helped us a lot.
