NX - 2nd Gen (2022-current)
Lexus Dashcam
Old Jan 26, 2024 | 07:11 PM
lsft's Avatar
lsft
Originally Posted by mplsrube
Have you experienced any issues with using CarPlay or Android Auto while recording video? Thanks!
You mean downloading video or the dashcam recording?
If you are downloading video from the dashcam you will need to disconnect from CarPlay as both uses Wi-Fi
Old Jan 26, 2024 | 08:38 PM
websurfer's Avatar
websurfer
Isn't the Lexus dashcam limited in the size of the SD card at 32GB?
Old Jan 27, 2024 | 03:27 AM
mplsrube's Avatar
mplsrube
9th Gear
Thanks! I was concerned I would have to disconnect CarPlay while recording. I watched the YouTube video you posted; good stuff! Thanks.
Old Jan 27, 2024 | 05:32 AM
lsft's Avatar
lsft
When it's recording, it saves to the SD Card and it will not impact CarPlay. It only impacts when you download videos from the dashcam.
Old Mar 1, 2024 | 06:03 PM
fitiam4me's Avatar
fitiam4me
Default FITCAMX vs CarPlay
Originally Posted by lsft
That is the integrated dashcam that is new in the US.
https://youtu.be/AhnJvX2b_Zc
If you want to see more about the FitCamX, I have reviewed it:
https://youtu.be/D6P8TGZA_NU
hello! Can I be in CarPlay and still use FITCAMX? Because it made me close CarPlay before connecting to the FitCamx. Is this how will always be or is there a way around it? Thank you in advance! 🙏
Old Mar 1, 2024 | 07:38 PM
lsft's Avatar
lsft
Dashcams that use Wi-Fi to connect will have to disconnect CarPlay. CarPlay uses both WiFi and Bluetooth. Unfortunately that is how it works. This is not a fitcamx limitation, but most dashcams on the market. You only need to connect to the fitcamx when you want to view the clips. Why would you want both connected?
Old Mar 4, 2024 | 12:56 PM
gallico916's Avatar
gallico916
I have a 2024 model with the Lexus dash cam and love it; There are a few things to consider
  1. If you have a wireless CarPlay or Android auto setup, you must disconnect the direct wifi with the car and then connect to the dashcam.
  2. The dashcam comes with a 16GB MicroSD card, which is suitable maybe for one day (YMMV), I swapped the SD card for
    256GB 256GB
    w/o any issue ( you need an industrial card that can sustain the heat.
  3. The camera is only capable of to1080P/60
  4. Lexus has a Windows and Mac Application if needed
Old Mar 4, 2024 | 12:59 PM
websurfer's Avatar
websurfer
  2. The dashcam comes with a 16GB MicroSD card, which is suitable maybe for one day (YMMV), I swapped the SD card for 256GB w/o any issue ( you need an industrial card that can sustain the heat.
Does this dashcam activate when someone bumps the vehicle?
Old Mar 4, 2024 | 01:15 PM
gallico916's Avatar
gallico916
The dashcam is automaticlly powered from the moment you strat the car till you turn it off.
Old Mar 4, 2024 | 02:04 PM
Droid13's Avatar
Droid13
I believe it has a parking mode available, but to use it you may need to find an alternate power source. I think the included power cable is designed to plug into existing harness by the existing LSS camera that only gets power when the ignition is on. To use parking mode with just about any dash cam, it needs to be wired to always on power. Some dash cams have kits that either come with a battery for providing parking power, or those that wire directly into fuse box, have an interrupter that will cut it off if the car battery gets too weak (to prevent it from going flat).
Old Mar 4, 2024 | 02:08 PM
gallico916's Avatar
gallico916
Make sens, but I'm also less worried about accidents when I'm parked.
Old Mar 4, 2024 | 05:42 PM
fitiam4me's Avatar
fitiam4me
I thought it needed to be! Thank you for the information. I appreciate it! Is there a video for my specific vehicle? Because the one I saw for the 22’ is not correct. I broke both clips trying to install 😔 they are sending me a new shell 👍
Old Mar 4, 2024 | 05:45 PM
fitiam4me's Avatar
fitiam4me
I Greatly appreciate your feedback. Very helpful 🤘
Old Mar 7, 2024 | 04:30 AM
lsft's Avatar
lsft
Oh no. When you get the new shell. Becareful installing it. Double check before you press hard on it.
Old Mar 13, 2024 | 01:09 PM
fitiam4me's Avatar
fitiam4me
Default Update On Dashcam
hi. They seemed to have sent me the wrong shell. So I removed the old camera and now I’m stuck. I reached out to them. But I’m thinking that I should just scrap this and get the OEM Dashcam. Which I can order for $300 including the wire kit. I can’t imagine it being any harder to install??? 🤞
Hmunster2
Apr 24, 2022 01:46 PM
TipsyTonio
Sep 19, 2021 04:02 PM
aflagg
Sep 17, 2021 11:52 AM
SethNaga
Jan 5, 2016 05:49 PM
