NX - 1st Gen (2015-2021)
Help! (Using 93 octane gas)
Old Feb 14, 2022 | 03:13 PM
PL080212's Avatar
PL080212
Default Help! (Using 93 octane gas)
So I accidentally put 93 supreme on my 2017 Lexus Nx I always put premium and today I made that mistake will it mess up ?!!
Old Feb 14, 2022 | 03:35 PM
PL080212's Avatar
PL080212
Default Help!
Hoping you guys can help ! So I own a Lexus Nx200t and I always put premium gas now today I made the mistake and put 93 supreme I’m panicking, will it do any harm?
Old Feb 14, 2022 | 03:38 PM
JDR76's Avatar
JDR76
No harm done.
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
93 is totally fine. Anything less than the recommended 91 octane would be worse. Though even if you had done 89 or 87, modern engines are smart enough to adjust for knocking and pinging. I wouldn't get into a habit of it though as the 200t has turbo and direct injection.
Old Feb 14, 2022 | 03:41 PM
AMIRZA786's Avatar
AMIRZA786
You are posting in the wrong section, but the answer is no. Check the manual, if it uses 87, than stick to 87, and if Premium is recommended, than you would use either 91 or 93. If it doesn't take premium, all you are doing is wasting money, but no harm
Old Feb 14, 2022 | 03:42 PM
PL080212's Avatar
PL080212
Originally Posted by JDR76
No harm done.
Thank you!!!
Old Feb 14, 2022 | 03:43 PM
PL080212's Avatar
PL080212
trust me I know I am but hey I needed to know asap no one was responding on another section I posted but thank you much appreciated!
Old Feb 14, 2022 | 03:45 PM
AMIRZA786's Avatar
AMIRZA786
You are good to go!
Old Feb 14, 2022 | 03:47 PM
Jakerin's Avatar
Jakerin
91 and 93 (are) premium fuels.
Old Feb 14, 2022 | 04:01 PM
LexBob2's Avatar
LexBob2
It'll be fine. No worries. Read in your owners manual or on the inside of the gas door and they'll explain things.
Old Feb 14, 2022 | 05:42 PM
The G Man's Avatar
The G Man
I am assuming premium is 91 octane. Here in the Northeast, we do not have 91 octane, only have 93 octane so that is all I use.
Old Feb 14, 2022 | 05:47 PM
LexMan2003's Avatar
LexMan2003
I'm in the northeast here in NJ and we have 91 octane. Usually many Sunoco stations offer it, as well as 93 octane.
My 2020 NX calls for (at least) 91 octane, but I typically use 93 because the 91 is not as readily available.
As long as you use an octane level that's AT LEAST what your vehicle calls for, you'll be okay. In fact, even in an emergency you can use a lower octane, but you'd best fill up with the proper octane ASAP.
Old Feb 14, 2022 | 07:40 PM
GS3Tek's Avatar
GS3Tek
Welcome aboard.
Both threads have been merged....looks like your question has been answered
Old Feb 16, 2022 | 10:19 AM
The G Man's Avatar
The G Man
We have Sunoco 91 here in Boston as well but I only use Shell gas. Years ago, a couple of my Audi had carbon build up in the intake and the mechanic told me to use Shell V-Power gas after the carbon cleaning and I have never had another issue with carbon build up.
PL080212
Feb 14, 2022 05:47 PM
Astrokat
Dec 3, 2018 06:10 AM
str8hust1a
Jun 13, 2012 04:57 PM
BATMANSC
Oct 10, 2008 01:31 PM
txgs300
Jul 16, 2007 03:19 PM
