NX - 1st Gen (2015-2021)
New wheel tpms question ?
Old Apr 26, 2020 | 10:20 AM
Pauljak's Avatar
Pauljak
Default New wheel tpms question ?
Hey everyone ! I will be getting my nx this week and want to keep the stock 18s and tpms for my winter setup and purchase new 20 inch summer wheels is it necessary that I put in another set of tpms or can I just install the wheels without I’m not too motivated to keep reprogramming each set every time I switch sets ? Will I be getting the dash light ?
thanks
Old Apr 26, 2020 | 10:28 AM
2017FSport's Avatar
2017FSport
You will need to get another set and program them. Otherwise, the light will stay on if they are on the car. Been there, done that.
Old Apr 26, 2020 | 01:07 PM
Pauljak's Avatar
Pauljak
what if I remove the stock wheels with tpms and install the new wheels without tpms and don’t do a reset the light should not come on ?
Old Apr 26, 2020 | 03:21 PM
no1SomeGuy's Avatar
no1SomeGuy
First time I swapped winters to summers I didn't have a TPMS programmer yet and drove for a couple weeks without changing sensor id's and it never complained or had any lights.
Old Apr 26, 2020 | 04:38 PM
2017FSport's Avatar
2017FSport
give it a try. see what happens. my personal experience wasn't so good but maybe yours will be different.
Old May 10, 2020 | 05:59 AM
scarlet27's Avatar
scarlet27
Hi no1, my wife will be getting her new nx300 soon and have been thinking winter tire/wheel package for it. We have a winter package with 2017 RDX w/ TPMS which are also 315MHz but they auto learn when you swap wheels.
I was hoping to use the RDX package with correct size centering rings but TPMS may not be compatible with nx300. Any thoughts on this? Also, it sounds like you found a programmer. What did you buy/borrow so I can consider one for purchase?
Thanks,
Jacques
Old May 10, 2020 | 07:13 AM
balance101's Avatar
balance101
Thanks,
Jacques
NX needs OBE relearning procedure. You can try ATEQ Quickset TMPS but you need to know the TPMS senor IDs -
https://www.amazon.com/ATEQ-QuickSet-TPMS-Reset-Tool/dp/B008SCWXN4. https://www.amazon.com/ATEQ-QuickSet-TPMS-Reset-Tool/dp/B008SCWXN4.
I ended up picking up Autel maxi TPMS TS508. It can read and relearn procedure and tire order. http://www.maxitpms.com/tpmscms/product/701.jhtml
The seller for the TS508 best price imo
https://www.ebay.ca/usr/auteldeals?_...72.m2749.l2754
Good luck.
Old May 10, 2020 | 07:32 PM
no1SomeGuy's Avatar
no1SomeGuy
Thanks,
Jacques
Autel TS5xx or TS6xx will do the job. I have a TS501.
Old May 12, 2020 | 08:39 AM
NSXT's Avatar
NSXT
thanks
Or get a Cloned TPMS kit.. No need to do anything in every flip. If NX had 2 TPMS config holder we wouldn't have this issue. I think the RX series can store 2 set of TPMS.
Old Nov 2, 2020 | 06:15 AM
scarlet27's Avatar
scarlet27
Originally Posted by balance101
NX needs OBE relearning procedure. You can try ATEQ Quickset TMPS but you need to know the TPMS senor IDs - https://www.amazon.com/ATEQ-QuickSet-TPMS-Reset-Tool/dp/B008SCWXN4.
Good luck.
Hi Balance 101, Ended up ordering a tp508 from the ebay seller you suggested. Very nice! We also purchased a winter set or wheels/tires from Lexus for the NX300.
Is the best plan to read the summer set (currently on car) TPMS IDs with the tool and then use the same IDs for each corresponding winter wheel location when installed so the computer thinks they are the same?
kolyan
Feb 25, 2016 09:22 AM
Aeromotive
Nov 3, 2014 07:26 AM
flektone
Dec 31, 2011 04:25 PM
NYC ES3
Wheels, Tires & Brakes Forum
Dec 13, 2008 11:42 AM
