NX - 1st Gen (2015-2021)
Maintenance required soon
Old Jun 22, 2018 | 12:58 PM
ukrkoz's Avatar
ukrkoz
Default Maintenance required soon
OK, I read FAQs, not there.
Maintenance required soon message started popping on the center display.
Unfortunately, it does not tell what kind of maintenance. Vehicle has 27 000 plus miles and had oil change done 2 000 miles ago. Oil meter was reset same time.
MOF, I brushed on scheduled maintenance screen and it said that vehicle still has approximately 6 000 miles to oil change.
Message does not have any numbers in it. Honda, eg, will do same message with a certain number to it, what points to which specifically item needs to be done.
How exactly do I determine what needs to be maintained then?
Old Jun 23, 2018 | 07:52 AM
ukrkoz's Avatar
ukrkoz
Read User Manual. Can't find that either.
No one?
Old Jun 23, 2018 | 08:59 AM
ukrkoz's Avatar
ukrkoz
Went through every setting on vehicle display. In Messages says No messages.
No indicators otherwise.
No idea.
Old Jun 24, 2018 | 09:53 AM
ukrkoz's Avatar
ukrkoz
Even went through the thick manual that came with the car.
Not a word. Mentions OIL maintenance required but nothing on Maintenance required soon.
I simply reset minder. Scheduled minder. There are two options - Reset schedule minder and Oil maintenance minder.
Old Jun 25, 2018 | 08:13 PM
ukrkoz's Avatar
ukrkoz
Thank you for contacting Lexus.The Maintenance Required Soon message will display in your vehicle every 5,000 miles to remind you of scheduled maintenance.
Even if none is.
Old Jun 25, 2018 | 08:27 PM
GS3Tek's Avatar
GS3Tek
I found this:
https://www.lexus.com/maintenance
30MO / 25K MI
• Rotate tires and adjust tire pressures as required
• Reset maintenance reminder light
• Road test vehicle
• Check installation of driver's floor mat*
• Inspect and adjust all fluid levels
• Visually inspect brake pads, calipers and rotors
36MO / 30K MI
• Replace engine oil and oil filter (0W-20)
• Replace air conditioner filter
• Replace brake fluid
• Replace engine air filter
• Replace smart key battery*
• Road test vehicle
• Inspect axle shaft boots
• Inspect ball joints and dust covers
• Inspect body
• Inspect brake lines and hoses
• Inspect brake rotor thickness and runout
• Inspect engine coolant
• Inspect exhaust pipes and mounting
• Inspect fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
• Inspect fuel tank cap gasket
• Inspect rack-and-pinion steering assembly
• Inspect steering linkage and boots
• Inspect transmission fluid
Old Jun 27, 2018 | 01:47 PM
ukrkoz's Avatar
ukrkoz
Thank you. Mine has 27 000 miles and pennies on ticker. Will you think, it's a bit farfetched to start encouraging a 30 000 miles maintenance NOW? Besides, it's sealed transmission, how you going to inspect ATF?
colfax
Oct 25, 2018 05:16 PM
jaishanker
Sep 7, 2018 04:21 AM
catsnmusic
Jun 9, 2015 07:32 AM
LDNN
Sep 3, 2011 06:02 PM
kcw884
Feb 10, 2007 06:10 AM
