Triple LED headlights
Picked up an NX with triple LED headlights and noticed the first time driving in the dark while the lights are extremely bright the distance seems to be rather short compared to my previous vehicle (xenon HID). It appeared the distance was only about 3 car lengths give or take and whenever I hit uneven areas of pavement watching the end of of the lit area fluctuate was not something I'm used to. Anyone else experiencing this with their LED lights?
In reality, the distance probably isn't any different than your HIDs were. With LEDs, the lense is a little sharper so you see the cutoff much better.
If you have a concern, feel free to take it to your dealer and ask them to adjust the lights. However, keep in mind that you can only go so far up before you hit the cutoff and begin to lose light.
With mine, on a flat surface, if I had to guess, I can see about 6-7 car lengths out. If i'm going down hill it can be as short as 1 car length depending on the angle of the car. At that point, I just turn the high beams on. Helped me this morning as I passed 5 deer on my way to work at 5am.
What is your opinion on the auto hi-beams? I'm very hesitant to try it since the lights are already insanely bright and I'm concerned about being that guy that everyone hates on the road with high beams on LOL.
Thanks for the feedback!
Interesting... I never considered that. I will give it a little time to adjust to it. My friend and I were blown away on how bright those lights are. It looked like daylight the first time we drove off with the lights on.
I think the high beams on the car are great, and they certainly outdo the HIDs on my Camaro and even outdo the high beams on my wife's IS.
I wouldn't concern yourself about "offending" someone. Use the car as its intended. They don't like it...ask them where they built the dam to contain the water because they are crying you a river.
Brightness and blinding oncoming drivers are two different things. You can have the brightest lights in the world but, as long as they are not aimed so high as to blind other drivers, you are fine. You can have much dimmer lighting but, if they are pointed high into oncoming traffic, then you will "be that guy".
If it's equipped with auto high beams then they automatically dim when there's oncoming traffic. There's a sensor that can sense light that does this so you don't need to worry about blinding people. It senses bright light so it also works when behind a vehicle
Lexus designed the system with thousands of hours of driving. I'm sure It will work just fine.
If someone flashes their brights at you, its probably some schmuck who is driving a 90s cavalier with big ole halogens that has no idea what they're looking at with that "new tech stuff".
I always look at it this way, they flash their brights at you for your STOCK lights, that's when you have a set of spot lights behind your grill (which I've considered doing for deer season, but it can certainly have multiple purposes
), turn THOSE on and blind the living crap out of them. Then maybe they will learn to keep their bs flashing to themselves.
LED headlights aren't all that unique these days. Keep an eye out for oncoming cars with them and you can see they aren't too bright or blinding. That is what your will look like to other drivers.
See how it works out? Have you read what you've typed? You're worried about using your car AS INTENDED because you're worried it will be too bright for the person coming the other way?
