NX - 1st Gen (2015-2021)
Green valve stem caps missing
Old Aug 12, 2015 | 12:10 PM
kchnew's Avatar
kchnew
Default Green valve stem caps missing
I have two green valve stem caps missing on passenger side of my NX. Don't know if they were missing from the beginning or some kids took them.
Should I get the OEM caps (I am assuming they are metal) or to get the non-OEM plastic ones to avoid the potential corrosion problem? any TPMS issue? Thanks a lot.
Old Aug 12, 2015 | 05:33 PM
legrunt's Avatar
legrunt
I don't think theres any issue with mismatched valve stem caps, unless you're a fashion **** or something. Lol....
Old Aug 12, 2015 | 05:54 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Get any caps you like, no issues. I got Lexus caps on my past RX and current IS, but I went cheap with the IS ones and they rusted.
Old Aug 13, 2015 | 02:51 AM
tresmith00's Avatar
tresmith00
take it in and see if the service department would replace them for free.
Old Aug 13, 2015 | 10:31 AM
kchnew's Avatar
kchnew
@corradoMR2, are the caps shown in your post for IS metal based?
I called 2 dealership in my area, the one closer to me wanted to charge $10, which is okay. But the other one that I got my NX from promised to mail some plastic ones for free. I really appreciate their effort.
Old Aug 13, 2015 | 12:32 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Yes, they're metal and you can get them on amazon, ebay, etc. I understand there are claims that metal caps may interfere with the TPMS, but I never had any issues with the RX nor IS in that regard.
If you want to be safe, there are chrome plated plastic caps like this if you want these, if not just get the plain ones from your dealer. Personally, I wouldn't pay 10$ to the dealer for them since they just add one for free on your next service if you ask.
Old Aug 13, 2015 | 04:47 PM
rogerh00's Avatar
rogerh00
Veteran: Air Force
The caps that came on my NX are chrome plastic with green letters---N2. Are those standard?
Old Aug 15, 2015 | 07:12 AM
dCota's Avatar
dCota
Hi all!
I was told the green caps are on only during transport to the respective dealer, but are then replaced with the metal (no logo) caps. That's what I've got on mine. Maybe dealer-specific?
Best!
dCota
Old Aug 15, 2015 | 08:23 AM
tsopranoMB's Avatar
tsopranoMB
those mean the dealership put in NITROGEN in the tires....
Old Aug 15, 2015 | 10:56 AM
ClaudeNX's Avatar
ClaudeNX
Default Nitro
If they were filled with nitro, we should not see such a difference between cold and hot tire temp.!!!
Or am I wrong, 33-38
Old Aug 15, 2015 | 07:06 PM
computerwi's Avatar
computerwi
I asked the dealer for the OEM caps back (which are metal colored plastic) and got 4 free. Those plastic caps are ugly in my opinion.
Correct. I opted out of this in my build, but my dealer includes this in the PDI for all their units. My argument, air is 78% nitrogen and I'm not landing a Boeing 777.
Old Aug 31, 2015 | 11:11 AM
jeffdawgfa's Avatar
jeffdawgfa
Metal caps will not interfere with your TPMS. The green plastic just means that (supposedly) they put 100% N2 in your tire. This is supposed to keep the air from migrating out as fast as regular (atmospheric air). Pure nitrogen for auto tires is a gimmick. A way for dealers/service shops to suck your hard-earned dollars from you. Think about it. The air you breathe is around 70% Nitrogen. When they mount your new tire do they do it in a room filled with pure N2? No. They do it in the shop so before they pressurize the tire, it is already filled with regular air. Air pressure at sea pressure is around 14.5 psi or something like that. IF they then pressurize your tire with N2 to 36 psi, you still are far from 100% N2 in the tire. The regular air is still in there.'
The reason they put nitrogen in airplane and space shuttle tires it to prevent the things from exploding. When a jet lands those tires go from 0mph to almost two hundred mph. That rapid acceleration generates a whole lot of heat. If you add HEAT+OXYGEN (in regular air)+Petroleum (RUBBER TIRES ARE PETROLEUM PRODUCT) then your are setting yourself up for a possible explosion in the tire. The N2 there can help to minimize that potential. Your car tires do not see that type of stress. Save your money. Don't let them sucker you into using nitrogen.
Old Nov 20, 2019 | 10:01 PM
ASE's Avatar
ASE
Valve Stem Bling Plastic caps don't corrode ... are not something anyone wants to steal ... weigh close to nothing ... and are close to free.
Old Nov 20, 2019 | 10:08 PM
ASE's Avatar
ASE
Old Nov 21, 2019 | 06:00 AM
ACP84's Avatar
ACP84
picked these up for NX...Like them because its plastic and wont cause corrosion in the winter...plus they look NICEEEEE
Amazon Amazon
