NX - 1st Gen (2015-2021)
Vibration when braking
Old Aug 25, 2023 | 04:01 PM
DiezDos's Avatar
DiezDos
Default Vibration when braking
Hi Everyone. Wanted to see if I can get some input on this. Drove my wife's 2016 NX the other day up to the mountains and noticed that the brakes were vibrating pretty hard when I was breaking down hill at about 55-60 mph. I instantly though of front brakes and rotors and so I replaced those and you can still feel it. Even on straight roads once I apply the breaks. I can feel it on the break pedal, almost like it bounces back on my foot when applying the breaks. Can anything else from the suspension components cause this?
TIA
Old Aug 28, 2023 | 11:05 AM
Rjngo's Avatar
Rjngo
Look into your wheel balancing and or control arm bushings
Old Aug 28, 2023 | 04:04 PM
LexMan2003's Avatar
LexMan2003
Could it possibly be something awry with your Anti-Lock Brake System ?
Old Aug 29, 2023 | 09:53 AM
DiezDos's Avatar
DiezDos
Thanks for the comments guys. I am going to start with rebalancing and see how that goes. If it persists then I'll start checking bushings.
Old Aug 29, 2023 | 11:26 AM
Lex2000TL's Avatar
Lex2000TL
If suspension is the culprit, you can see it in uneven tire wear. Check rear brakes as well, as vibration can transmit from rear brakes. Check tire balance again. Not every tire shop does nice job in balancing. Lastly, I would take a look at rims. If one of the rims has a bent, especially on inside diameter, tire balancing may not fix it (seems counter intuitive) but you will feel it. However, in this case you should also feel it as slight vibration at high speed and without braking.
Old Aug 31, 2023 | 07:15 AM
DiezDos's Avatar
DiezDos
Crazy but the rebalancing did it. I never thought I could get vibrations that bad from needing balancing. Maybe just accumulated from the terrible Colorado roads. They also confirmed that the wheels were not bent.
Either way. Thank you all for taking the time in responding! Now I know a few other things to check if it was to happen again.
Old Aug 31, 2023 | 07:58 AM
Rjngo's Avatar
Rjngo
That’s a great news!
Glad the issue was rectified
Old Sep 14, 2023 | 03:19 AM
AbigayleLabadie's Avatar
AbigayleLabadie
2nd gear
Thanks for the suggestions, I will check it and if I still face this issue, I will update you.
Old Sep 14, 2023 | 05:14 PM
850R's Avatar
850R
Have a shop check your rear brake rotors. Rear rotor are much thinner, often solid/non-vented varieties. Thus, they can be easily warped in hard braking, or during sustained operations with the parking brake on. If you are feel vibration in the pedal, the rotors will be badly warped, maybe even visible to the naked eye.
jnguyenlex
Jul 29, 2024 06:29 PM
iceman1212
Jan 24, 2020 08:53 PM
OldLs400
18
Sep 30, 2019 11:41 PM
Och
GS - 1st Gen (1993-1997)
13
Sep 21, 2004 05:26 PM
Horta
Jul 27, 2002 08:18 PM
