Has anyone ever switched out a torque converter? need advice
Old May 30, 2009 | 07:38 PM
Ultra Vip's Avatar
Ultra Vip
Default Has anyone ever switched out a torque converter? need advice
just like what the title says has anyone ever switched one out?
want to know what to look out for what extra parts i need or should replace while im doing it.
dont want to have the trans out and be @$#% i dont have that part. since the nearest lexus dealer is like 2 hours away. lol
thanks
Old May 30, 2009 | 09:23 PM
trukn1's Avatar
trukn1
NELOC Mod
Only person I know that has had their torque converter changed on a GS is KevinGS. Gonna be a little difficult to get hold of him since he doesn't visit as often.
Old May 30, 2009 | 09:43 PM
beez43's Avatar
beez43
um i thought kevin doesnt work on his car?!?
Old May 31, 2009 | 04:35 AM
Rising_Sun's Avatar
Rising_Sun
Pulling the trans is typically a PIA, since you will lose plenty of fluid. It's a good idea to replace the trans filter and fluid. Also check your Trans mount, I'm sure it's not going to last long with the new Stalled convertor.
Old May 31, 2009 | 05:43 AM
MRISF's Avatar
MRISF
make sure when u put he new torque converter in you fill that up with trans fluid first before putting it in...also make sure when u put the new one in you line up your dowels and it slides in place for you, dont want to leave it hang out some and then have a problem.
Old May 31, 2009 | 09:14 AM
Ultra Vip's Avatar
Ultra Vip
thanks for all the tips guys.
so all i need is:
converter
trans fluid
new mount (maybe)
trans oil cooler
anything else? new seal or anything else like that?
Old May 31, 2009 | 10:51 AM
Rising_Sun's Avatar
Rising_Sun
The rear main seal comes to mind for maintenance replacement.
Old May 31, 2009 | 06:57 PM
trukn1's Avatar
trukn1
NELOC Mod
Originally Posted by beez43
um i thought kevin doesn't work on his car?!?
While this may be true, I actually have seen him turn a wrench or two since I have known him. Was a time when he was changing his exhaust out, like every other weekend since he could not decide which one he liked better. As I stated, he was the only one that I knew that has had his torque converter changed out. Whether or not he did it himself is another issue.
Old May 31, 2009 | 08:26 PM
Ultra Vip's Avatar
Ultra Vip
where can i get said rear main seal???? only from lexus or can you order it online? a link would be nice please.
also do i need ot order a new thrust bearing?
i should only use AT toyota syn atf right?
is sewellpartsonline.com my best bet for parts?
mic575
Sep 10, 2016 06:09 AM
vegas_sc4
Nov 16, 2009 06:09 PM
JohnEd
Feb 5, 2007 12:25 PM
Xer0 SiN
Feb 22, 2006 12:53 AM
dunn378
Dec 19, 2002 09:57 PM
