SC400 trans flush
Old Feb 4, 2007 | 11:47 PM
JohnEd's Avatar
JohnEd
Default SC400 trans flush
Guys,
I want to change my trans over to synthetic ATF. I need to get the old ATF out of there. The pan only gets two quarts out and the system holds 8.7 quarts. How do I get it all out? Isn't all the rest of it in the torque converter? Help!
Thank you
John
Old Feb 5, 2007 | 12:13 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Originally Posted by JohnEd
Guys,
Thank you
John
Flush can be bad... What I would do if you are convinced every last bit needs to be changed, is to get two buckets - one filled with many quarts of toyota t-iv atf or Amsoil universal atf (you'll need probably 10 quarts)...
pull a trans cooler line so that the trans sucks in fluid from the bucket, and discharges the old into the other bucket...
Old Feb 5, 2007 | 10:35 AM
MJHSC400's Avatar
MJHSC400
Exactly-- This trans is a common unit in many Toyota trucks and SUVs like the Tundra and Sequoiah for example-- maybe a different sized pan, but doubt it--
All of the different variations call for a 12qt flush procedure, which will cost you $150 at the dealer, or you can buy the Toyota TIV (only one to use I think) for about $60 ~ ish-- My nearest Toy dealer charges $5 per quart for the stuff.
I'd say just flush it once and do a drain and fill after that every 15k or 30k depending on how much you drain and fill-- but that should keep your trans safe and operating tip-top....
Old Feb 5, 2007 | 12:25 PM
JohnEd's Avatar
JohnEd
Default trans flush
Those first four words of Cody's post did it. I have heard before that lament "after the flush in went down hill. Lots of Lex posts say it solved their problem. I don't haver a problem and want it to stay that way. Sooooo! I will go with the 2 quarts of Tot type IV and do the flush when I have a problem starting.
Thanks Cody and others that responded to the post and PM'd me.
John
dannysc400
Sep 4, 2010 08:55 PM
vegas_sc4
Oct 19, 2009 03:25 PM
HotBoy
Maintenance
Dec 30, 2003 09:09 PM
Lvangundy
Mar 14, 2002 10:39 PM
VQT
Nov 1, 2001 09:02 AM
