Bad cv boot at 90K?
Old Oct 1, 2003 | 10:49 AM
GS3Tek's Avatar
GS3Tek
Default Bad cv boot at 90K?
Has anyone have their CV boot go out at 90k? I get this from the front
making a right turn only.
Old Oct 1, 2003 | 02:13 PM
PhantomZX's Avatar
PhantomZX
I think that CV boots/joints are only used on front wheel drive cars. Is it your steering boot that went out?
Old Oct 1, 2003 | 02:58 PM
GS3Tek's Avatar
GS3Tek
I'm not too familiar to know the difference. All I know is when I make a right turn, fast or slow, it click click
click. I'm going to take it in for a look. Basically, is it this too early for "cv boot?" to go out this early?
Old Oct 1, 2003 | 03:35 PM
Pianoman72's Avatar
Pianoman72
Hey man the CV boot just holds grease in there and keeps contaminants from screwing up your joint.
Yeah it can tear if a rock hits it or whatever. Then when you look behind your wheel there will be grease splattered everywhere. I had some recent experience with this and if one boot goes out on one side be checking the other side because once they reach their life expectancy they can go out at any moment and you want that grease in there, not all over the place. lol
The boot will not make a *click* sound since it is not made of metal. Maybe somethine else?
Old Oct 1, 2003 | 04:05 PM
LXOGOOD's Avatar
LXOGOOD
crazygs: I moved your thread to the maintence forum in hopes that you will get more replies from members here. Good luck with your problem....
Old Oct 1, 2003 | 06:16 PM
Guru's Avatar
Guru
If your CV joint is clicking it is already gone and needs to be replaced but if it is in front on a GS you have something else wrong. I would take a look at the tie rods and ball joints. Those are common to go around 120,000 miles if you have rough roads.
Old Oct 2, 2003 | 10:43 AM
GS3Tek's Avatar
GS3Tek
Thanks for all the response. Thanks for the new move LXOGOOD. Still learning.
However, at 90k, is this a little too early? Considering SoCali is not that rough.
Old Oct 2, 2003 | 10:49 AM
VVT-i's Avatar
VVT-i
I agree with Guru and the GS is rear wheel drive. I check all the suspension components first and make sure to check the sway bar bracket and mounting bracket. I found some of the sway bar bracket bolts loose on Bit and 1Sick cars.
Old Oct 2, 2003 | 10:53 AM
GS3Tek's Avatar
GS3Tek
Wow! That's enlightening...and cheap to fix yourself.
Old Oct 2, 2003 | 01:37 PM
VVT-i's Avatar
VVT-i
But make sure you check the right front wheel bearing too. If the wheel bearing goes bad, it will make clicking noise on turn and some type of roaring noise on straight line. Good luck.
kg19989
Sep 15, 2010 10:44 AM
danny10989
Mar 30, 2009 11:01 AM
j stuff
13
Aug 26, 2008 11:29 PM
infa_red
13
Jun 10, 2007 11:41 AM
elvingomez
GS - 1st Gen (1993-1997)
12
Dec 16, 2003 10:21 AM
