Air Conditioner blowing hot air on 92 LS400
Old 07-25-11, 04:06 PM
sdshaddox
sdshaddox's Avatar
Default Air Conditioner blowing hot air on 92 LS400
Air Conditioner blowing hot air on 92 LS400.
I checked all fuses and none blown.
The compressor isn't clicking on.
any ideas?
Old 07-25-11, 04:07 PM
Hilux22RE
Hilux22RE's Avatar
More info would be nice.
Was it working before??
Old 07-25-11, 04:15 PM
sdshaddox
sdshaddox's Avatar
was working great til last Thursday. I drove to San Diego about 90 miles and worked all the way down. I parked for a few hours then started home and air was blowing hot air.
Old 07-26-11, 04:36 PM
uuuuu
uuuuu's Avatar
While the car is running (with climate control set to cold temp and A/C selected), short the compressor relay and see if the compressor clutch engages the pulley (you can see it start spinning). If so, then maybe your refrigerant level is low. Has the system been converted to r134a or does it still have the original r12?
Old 07-26-11, 05:57 PM
305ls400
305ls400's Avatar
you might just have a leak if it was working before you might just need to add refrigerant that all also buy a leak sealer and add it. when you buy the refrigerant at any auto parts or ato zone it comes with a gauge to check the level, important use the same refrigerant you have on the car if you change it to r134a or if you still have r12.
Old 07-26-11, 07:46 PM
91LS400vgb
91LS400vgb's Avatar
read this thread:
https://www.clublexus.com/forums/ls4...r-problem.html
2v1g
06-30-19 11:23 AM
Rubin85
09-08-16 01:42 PM
wise2k
06-27-13 07:17 AM
D.K.
Maintenance
12-26-02 10:50 PM
Quick Reply: Air Conditioner blowing hot air on 92 LS400
