SC 430 Code P0440 and P0446
Your Vent valve is on the passenger side of the valve cover, it's a solenoid that hooks up to the intake. The VSV itself could be defective or you got some broken hoses.
0440, I came across this thread and low and behold, I checked the first thing mentioned regarding the EVAP line with the green cap and the line was disconnected.my check engine light is gone for the time being because I already erased the codes so hopefully it doesn't come back. Thank you GS4_FIEND!!!!
@SC43062 My scenario is similar just different solutions were tried. Ahhh these evap issues are so frustrating. I went to my car guy 4x over this! Started with generic P0440 error.
1st time, he replaced the fuel cap, code returned. Cleared the code but P0440 returned.
2nd time, he replaced one of the evap hoses. Cleared the code and same code returned.
3rd time, he dropped the fuel tank, did smoke test which turned out ok no leaks and replaced the overfill valve because it looked worn out. Cleared code. Two days later, I got these codes below!
P0440 (current)
P0446 (current)
P0440 (pending)
P0441 (pending)
P0446 (pending)
Car guy introduced new codes! I am really annoyed. Not just the original code but 2 new ones, P0441and P0446. So 4th time, he checked all the hoses and replaced the ones he didn't replace the 2nd visit. I don't remember him doing the one with green cap on the passenger side like another member mentioned here. He cleared the codes and I drove over 100 miles but now the P0440 and P0446 returned both showing as current codes and also pending codes. What is going on!
I don't want to bring my car back again yet so I will attempt to check the green cap. Ugh. It's been 10 years since this thread was opened so I hope I can get some helpful advice and tips from whoever sees my post.
having same issues with my 2002 SC430, with
approximately 86k miles. Been having issues for
past couple of years & Low gas mileage aswell.
When I drive for longer distance than normal check engine light doesn't come on until the next time I use the vehicle. My normal commute to work is only about a mile to work in each direction & no CEL comes on at all. Again only after longer distances. I'm researching now to narrow down the possibilities & am hoping I can fix it with just changing the Vapor canister purge valve Doorman part # 911-488 or I believe the Vacuum Switching valve/ vent valve. Charcoal canister price new over $700. Used anywhere from 100 to 300 buy you never know how much mileage donor vehicle had;
probably more then mine. I suggest to keep researching on line & look at different videos before bringing to shop; who will probably do the same thing. Good luck, Happy Blessed Holidays & God Bless You & Yours.
