HELP! brake lights dont work.
Old Feb 15, 2011 | 02:52 PM
fleecer's Avatar
fleecer
Default HELP! brake lights dont work.
1995 sc300.... brake lights dont work. have no idea how long this has been going on either lol. ive changed bulbs, switch, and fuse in the wheel well. rest of the lights (reverse turn tail and blinkers) work without a hitch. ive even checked batt. cables and cleaned the grounds. if anyone else had any ideas, please lemme know. everthing else seem to work except the fog lights but i dont think its related. if anyone in atlanta wants to come fix it, im willing to pay for your time.
thanks
alan
Old Feb 16, 2011 | 09:00 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
It might be time to check out your brake switch, below the pedal, to see if it is working properly, plugged in, wiring damage, etc.
Old Feb 16, 2011 | 11:39 PM
fleecer's Avatar
fleecer
swapped it out for a new switch already. didnt work. felt like i set 25 dollars on fire.
Old Feb 19, 2011 | 05:17 PM
VVT-i's Avatar
VVT-i
Your SC has a tail light failure sensor relay box in the trunk. It's a small yellow box locate in the left rear of the trunk. You have to remove the trunk cover to see it. This box may be short out. Also, check the wire harness that run along the trunk hinges on the left side. After the trunk has been opened and closed for so many thousand times the wire harness get stress out and broke the wires.
Check your tail light failure sensor first.
Old Feb 20, 2011 | 12:44 AM
fleecer's Avatar
fleecer
thanks bro..... will check it out as soon as i wake up. sounds promising.
Old Feb 21, 2011 | 09:22 PM
TuanLegend's Avatar
TuanLegend
this might be the answer to my problems! thanks
Old Feb 22, 2011 | 02:45 PM
fleecer's Avatar
fleecer
swapped out the yellow box in the rear.... no help. any other suggestions? wondering if my shifter needing to be pulled up to get the key out could have anything to do with my brake lights. gonna borrow a multimeter from a friend and see if i can find out anything more.
Old Feb 23, 2011 | 04:22 PM
fleecer's Avatar
fleecer
anyone in the ATL area that fixes this problem gets 80 dollars cash..... hit me up. im tired of trying to figure this out. prolly something really simple.
Old Mar 5, 2011 | 09:28 PM
TuanLegend's Avatar
TuanLegend
u check ALL your fuses in the kick panel?
Old Mar 6, 2011 | 04:55 AM
fleecer's Avatar
fleecer
yes... checked them all. even the ones under the hood.
Old May 23, 2023 | 01:02 PM
/Aerostar\'s Avatar
/Aerostar\
Any update?
RRocket
IS - 1st Gen (2001-2005)
Feb 3, 2018 08:51 PM
2000ESLEX
Aug 21, 2014 04:19 PM
mayjah
15
Aug 18, 2013 09:46 PM
speed_Demo
Maintenance
Jul 19, 2010 09:10 PM
racerjim
Maintenance
Jul 15, 2009 05:46 PM
