1LS400 code 12&13
Old Feb 9, 2009 | 06:07 PM
asianrob's Avatar
asianrob
Default 1LS400 code 12&13
recently my car just started to act up. and it got worse. now...when ever i turn on my car id say about 15-20 mins of driving it would jsut shut off. has power but shuts off. i ran the CEL and it came up as 12 (RPM signal- no signal) and 13 (RPM signal open or short)
i just replaced the crank angle sensor or the crank position sensor. and it is still doing the same thing..
the weird thing is.. is that on cold start it would misfire untill it warms up a little and when i have it under load it would misfire at 3K+ RPM.
here are somethings i did to the car when i bought it
new water pump
new timing belt
new serpentine belt
new plugs/wires
I have not installed new Fuel filter or rotors.
i'm stumped at this and have been looking at the schematics and i guess tomorrow i'mma have to start from the Crank angle and work my way out from there.. any thoughts? or comments.... i tried searching and found a thing or two..but i want to make sure
one of the threads said something about not getting signal...
thanks...
Old Feb 9, 2009 | 08:49 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
I would check the wiring to your crank position sensor, and also check the wiring to both of the cam position sensors.. Its common for those wires to not be put back in their holders, and the belt rub through them.
Old Feb 10, 2009 | 05:06 AM
asianrob's Avatar
asianrob
thanks i'll check on those when i get back to the shop. is there something i else i should look at to?
Old Feb 10, 2009 | 10:27 PM
asianrob's Avatar
asianrob
update.
changed rotors etc...
now its just throwing 13
and i found out it is off 1 tooth.
but still acting the same.
Old Feb 11, 2009 | 09:31 PM
asianrob's Avatar
asianrob
got it all solved! i just had to retrace the crank position and re wire it. one of my wires was crushed when who ever messed with the condenser.
LiCelsior
32
Nov 4, 2025 11:31 PM
diamondave
Mar 21, 2013 03:08 PM
ki_soarer
Aug 2, 2011 12:21 PM
NSeagle78
Jul 7, 2011 04:49 PM
ROLEXUS400
Jul 22, 2010 08:28 PM
