MAX Cold is COLD; Everything Else HOT!!
Old May 5, 2008 | 02:14 PM
dknoxking's Avatar
dknoxking
Default MAX Cold is COLD; Everything Else HOT!!
Car is a 1998 LS 400. AC blows hot air (even when off!) EXCEPT when set to MAX COLD! I know this has been posted previously, but I have yet to see a justification or answer.
My mechanic (non-dealer) is also confused.
Please help.
Thank You, David:confused
Old May 5, 2008 | 03:34 PM
Debonair's Avatar
Debonair
See below. Print this out and take it to your mechanic. If he has Alldata, Shopkey/Mitchell On Demand, etc he should be able to find this stuff on his own. If he does not make him give you a discount for doing the research for him.
Attached Thumbnails MAX Cold is COLD; Everything Else HOT!!-98ls400-ac-diag.gif
Old May 5, 2008 | 03:53 PM
VVT-i's Avatar
VVT-i
Check your room temp. sensor. This sensor is located on lower left dash cover(the cover below the steering column). If somebody work in that area before may left the sensor unplug. The sensor is right under the ignition key, you will see a very small vent in that area. If you take that lower dash cover make sure it's plugged in both sensor wire harness and the little yellow hose.
Old May 5, 2008 | 06:42 PM
dknoxking's Avatar
dknoxking
Thank You! Much appreciated!
Old May 5, 2008 | 06:43 PM
dknoxking's Avatar
dknoxking
Thanks Very Much!
Old May 6, 2008 | 09:03 AM
vwynn's Avatar
vwynn
nice.. something i was hoping to see!
no more Hot winters.. n Cold summers =]
black_LS
Jun 20, 2024 08:22 PM
Cthopkinsc
Apr 22, 2016 07:35 PM
jboy
Jun 12, 2009 09:20 PM
Blackxfire
RX - 1st Gen (1999-2003)
Feb 8, 2009 11:23 AM
tbrdb0b
Aug 13, 2007 07:34 PM
