Is it bad to take out a gasket that is located after the cat? By doing this, it is creating a a little gap, making the car sound louder. Any negative effects?
Thanks in advance!
Thanks in advance!
WIll likely cause an issue with the Safety/Emissions inspection if your state requires it. I know if you were in NC and you brought your vehicle in for me to inspect it, I would have to fail it due to the exhaust system having an audible leak. But other than that I think no real issues would be of concern.
Lexmex
close
- Join DateApr 2004
- LocationMiami, Florida
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:211 Times in 176 Posts
I have had such gasket fail on me and had to have it replaced down here, that sound is not even remotely good to the ears. Like guitarmike said, that kind of leak will fail you in a bunch of places (but not here in Mexico
.exhaust leaks sound like crap, not worth it...
idk how the exhaust is on the 2IS, anyone got a pic of the underside of the car?
Its a y pipe after the cat.Originally Posted by PureDrifter
exhaust leaks sound like crap, not worth it...idk how the exhaust is on the 2IS, anyone got a pic of the underside of the car?
Quote:
i found one in the 2is forums, my idea wasnt going to work anyways so you need to change the rear section Originally Posted by Hartawan
i was wondering if a muffler delete would work/sound good on a 2IS but it wont as there are only 2 main mufflers, in my LS there were FIVE!
personally.. if it was me.. i would buy an exhause gasket ( very cheap ) and fix it... cuz
- too loud
- and your loosing back pressure ! i would sugest to perfect you exhause system !
Thnx.. Drive Safe
- too loud
Thnx.. Drive Safe
