O2 sensor brands make a diff?
Old Jan 10, 2007 | 12:19 AM
Hit Man X's Avatar
Hit Man X
Thumbs up O2 sensor brands make a diff?
Hey everyone, need some opinions/input. My '96 needs front O2s.
I see all sorts of options here:
Universals
-Bosch
-Denso
Direct Fit
- Denso
- Bosch
- Walker
I have the cash for the pair of Denso direct fits, but will any of the others work well? I can get two direct fit Walkers for about $10 more than ONE Denso direct fit.
Old Jan 10, 2007 | 07:22 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Quality quality quality...
The Denso stuff is better quality. Does that mean that the Walker brand will be crap in a month, probably not, but, I will guarantee the Denso's will be more accurate, longer... Same goes for Bosch - Bosch is quality, OE stuff... I haven't even heard of Walker o2 sensors and I work at a repair shop...
The only difference between direct fit and universal is that direct fit already have the right pigtail on them, whereas universal, you have to wire yourself...
Old Jan 10, 2007 | 07:40 AM
Lexmex's Avatar
Lexmex
In the RX300 forum, we have some O2 sensor issues and I always recommend to stick with the Denso. I remember a few people reporting issues with the RX300 with the Bosch, but that may be something endemic to our engine/ECM group.
My uncle has a garage and he has used the Bosch without issue on European vehicles, but the Japanese, he sticks with Denso.
Old Jan 10, 2007 | 07:45 AM
mitsuguy's Avatar
mitsuguy
That's pretty much how we do it around here too... anything japanese in origin gets ngk/denso parts...
Old Jan 10, 2007 | 03:31 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Basically what I figured. I can repair anything on my fleet, so I'm not scared to do wiring... but my concern about the "universal" units durability over time.
I plan to solder them into place, not crimp. But can these hold up to 70-100k miles of use with extreme heat and still accurately read my A/F?
Not interested in doing something half assed.
Old Jan 10, 2007 | 03:37 PM
Lexmex's Avatar
Lexmex
Well, I kind of do things half assed like toss in high octane racing gas (the variety just before it gets into leaded) along with experimenting with octane boosters and a lot additives, and my original OEM O2 sensors keep a ticking.
Old Jan 10, 2007 | 03:39 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
104 unleaded won't do a damned thing to O2 sensors.
Just wondering who's had long term universals installed...
Old Jan 10, 2007 | 04:12 PM
mitsuguy's Avatar
mitsuguy
if theres more than $50 difference (universals being cheaper), I'd do the universal ones, it's just the plug that makes the difference - the sensor itself is the same (so long as you get the proper universal sensor, heated vs not heated, etc)...
and of course so long as the wiring is done properly, there will be no difference in reliability...
Old Jan 10, 2007 | 04:13 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
There is a SEVENTY dollar difference EACH between the direct fit Denso and the universal four wire Denso.
Old Jan 10, 2007 | 04:15 PM
mitsuguy's Avatar
mitsuguy
when my Talon was running, the ONLY gas it got once it was on the big turbo was MS109, 105 octane, unleaded fuel... never had any issues at all with it...
leaded stuff kills o2 sensors fast, especially when that's all you use... however, if you use leaded gas just every once in a while, and normal gas the rest of the time, the standard gas tends to clean the o2 sensor to some degree...
I've seen 100% dead (from leaded gas) o2 sensors start working after some hard runs with standard unleaded... granted they die quickly when the leaded goes back in, but, it's definitely interesting...
Old Jan 10, 2007 | 04:16 PM
mitsuguy's Avatar
mitsuguy
wire the **** yourself... save the money... the sensor is the same, just the plug is the only difference...
f- that $70 difference...
what kind of prices have you found for the o2 sensors??? I show fronts and rears, rears being quite a bit more expensive... which ones do you need?
Old Jan 10, 2007 | 06:44 PM
Lexmex's Avatar
Lexmex
Oh I was higher than 104, gas burns like s..t at this altitude, but point well taken.
Old Jan 10, 2007 | 07:43 PM
mobilyte's Avatar
mobilyte
i replaced the front o2 sensors on my LS with denso universals, no issues at all.
Werner05
Jun 18, 2017 07:45 PM
ayroman
21
Aug 19, 2013 08:55 PM
haydog
IS F (2008-2014)
Sep 24, 2012 03:50 PM
dcapo
Aug 2, 2011 03:30 PM
asadchinoy
RX - 1st Gen (1999-2003)
15
Sep 22, 2006 04:32 PM
