E-brake light comes on
Old Oct 15, 2006 | 08:07 PM
philES300's Avatar
philES300
Default E-brake light comes on
1997 es300
In the last week or so, I have noticed the the BRAKE light that comes on when you hit the E-brake has been flashing once and a while. Has this happened to anyone else?
Old Oct 15, 2006 | 08:37 PM
mobilyte's Avatar
mobilyte
brake fluid may be low, check the level on the master cylinder reservoir.
Old Oct 16, 2006 | 12:23 AM
0l33l's Avatar
0l33l
It may be the fluid, but it may also be a faulty sensor.
Old Oct 16, 2006 | 05:51 AM
Tammy's Avatar
Tammy
Always a good idea to have the four sets of brake pads checked for excess wear, prior to topping off the brake fluid reservoir.
Old Oct 16, 2006 | 10:21 AM
philES300's Avatar
philES300
thanks. my friend was thinking it could be the sensor.
Old Oct 16, 2006 | 04:17 PM
mobilyte's Avatar
mobilyte
are you guys referring to the brake fluid level sensor or brake pad wear sensor?
Old Oct 16, 2006 | 07:16 PM
steviej's Avatar
steviej
Toyota/Lexus reservoir level sensors are very sensitive. Even when the fluid is within the inscribed Min/Max lines you can still get the warning light. Usually happens when you go around a corner or come to a stop (liquid in res. is not level or sloshes).
Just bring the level up to max. in the res. with new fluid and the light should go away. If it does not, then you may have other problems. First start with an emergency brake inspection.
I am pretty sure it is just the fluid level.
steviej
Old Oct 16, 2006 | 09:21 PM
philES300's Avatar
philES300
Im glad i joined this forum
sam12345
Mar 16, 2015 09:39 PM
AlexusAnja
RX - 1st Gen (1999-2003)
Nov 30, 2010 08:19 AM
mrchacon
Jun 24, 2009 06:09 AM
azari
Dec 25, 2005 06:54 PM
AaronE
Maintenance
May 12, 2004 09:50 AM
