Tom (TWG1160)
Old Nov 20, 2005 | 08:03 PM
TWG1160's Avatar
TWG1160
Default Tom (TWG1160)
Hi - I am a first time user -
Is there anyone that can help me? I have a 1993 Lexus SC400 - My problem: NO HEAT -
I've topped off the radiator - so it is full of anti-freeze - and have installed a new thermostat - Still, no heat -
I have put the dail control to "HOT" - and still only cold air comes out
Anyone have this problem? And are you willing to share with me how you solved it - without it costing you a arm & leg?
I will watch postings or you can email me directly - TWG1160@AOL.COM
THANKS
Old Nov 20, 2005 | 09:25 PM
nthach's Avatar
nthach
THANKS
bleed the cooling system. Find the fill plug on the upper water outlet - it's a 17mm plug. And then if you have it, follow the filling instructions on the coolant tank.
Old Nov 22, 2005 | 07:34 AM
TWG1160's Avatar
TWG1160
Thanks for the reply and help - will try this - hope it solves my problem
Old Nov 22, 2005 | 04:37 PM
T0ked's Avatar
T0ked
If the bleeding doesn't so it, do a search on "heater control valve". Notorious for going out. A simple temporary fix is available. Permanent fix would be to replace the valve.
Old Dec 11, 2005 | 07:06 PM
TWG1160's Avatar
TWG1160
THANKS FOR THE HELP - I'm going to look for the tempory fix for now - going to look in the heater control valve - is that correct?
Old Dec 12, 2005 | 09:44 AM
csaxon's Avatar
csaxon
Click on the "search" button and enter what your looking for i.e. heater switch or heater control valve".
Marvin5349
Aug 19, 2017 07:14 PM
bigrx
RX - 1st Gen (1999-2003)
Nov 14, 2014 06:03 PM
aeropartz
Dec 22, 2009 02:12 AM
Farino81
Dec 13, 2009 10:06 PM
nsx01
Dec 4, 2003 01:05 AM
